Old 07-19-2018, 06:17 PM   #1
GaryBD   GaryBD is offline
Is it harmful to haul a bike with the rear tire on the ground in neutral?
Is it harmful to haul a bike with the rear tire on the ground in neutral? I just put Together my RPS hawk. I was going to take it to a farm to break in. I do not have a license plate on it yet. I’ve seen these hitches where the front wheel is on the hitch in the rear wheel is on the ground in neutral. Is this harmful to the bike?
I do have a 4 x 8 Harbor freight trailer if I need to haul it on a trailer. But I’m not very experienced with that.
Old 07-19-2018, 06:25 PM   #2
ChrisWNY   ChrisWNY is offline
ChrisWNY's Avatar
Personally I'd trailer it rather than haul it with the rear tire on the ground...in the event the bike somehow winds up in gear while being dragged, it could cause damage. A trailer would be a much better option...better safe than sorry. You can rent motorcycle trailers from U-Haul for less than $20 per day.
2018 RPS Hawk 250cc
Mods so far:
1. Mikuni VM26 Carburetor w/#115 main jet
2. 17T/45T JT sprockets
3. JT 428 X-ring chain
4. Air box mod
5. Hawk Digital Cluster
6. Aftermarket IMS shift lever
7. Performance Aftermarket Exhaust
8. 295mm Nitrogen Gas Monoshock, 20W oil front forks
Old 07-19-2018, 07:32 PM   #3
Ariel Red Hunter's Avatar
I would recommend that you remove the chain before you do this. No way to harm the transmission without a chain...ARH
Old 07-20-2018, 12:26 AM   #4
Sochin   Sochin is offline
Sochin's Avatar
I have one of these, and I haul if it is less than 10 miles without any damage.
1983 Honda Xl600R
2016 Ducati Multistrada 1200S DVT
Old 07-20-2018, 12:57 AM   #5
kirbo7106's Avatar
I think I would load the Hawk up in the trailer. You don`t get a lot of miles out of motorcycle tires, so this would save on wear and tear.
Dan-O
-2018 Tao Tao HellCat - DOA
Old 07-20-2018, 01:12 AM   #6
pete   pete is offline
pete's Avatar
remove the chain and you will have no issues...
I have towed bikes 1000s km like this..
The only issue is if you get a flat rear tyre while
riding you have to fix it before you can tow the bike home..
this pic is the day I picked the TTR up....
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 07-20-2018, 03:07 AM   #7
pete's Avatar
You will ware far more rubber off the tyre riding it the same distance..
towing it..theres no drive load / no brakeing load / little heat build up
in the tyre...less weight as no rider....
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
Old 07-20-2018, 07:31 AM   #8
Mudflap   Mudflap is offline
Like ARH said, remove chain and it works fine. I've towed a bike from California to N Carolina and back with no problem.
Old 07-20-2018, 07:55 AM   #9
Removing chain.
Thanks everyone for the info. In case i do tow on road sometime, how do most people take the chain off? Do you remove the master link or take off the back wheel? Just curious what ends up being easier
Old 07-20-2018, 11:42 AM   #10
i wouldnt worry about it. put it on there chain and all and go. but hey thats just me! im the only person that would start a 18,000 mile trip with bald front tires!
2016 hawk
kaw h1 400 tripple
13' long chopper in progress
2009 johnny pag bar hog
Old 07-20-2018, 12:07 PM   #11
I remove the master link. Its OK to tow it for a short distance with the chain in place but the transmission isn't being supplied with oil.
Old 07-20-2018, 01:34 PM   #12
Tim, is this the same bald tire you had last year? lol Have a safe trip.
Old 07-21-2018, 03:29 PM   #13
nah there good this year. but one made 9000 miles till it started bouncing about mid canada! the other one made to within 400 miles of home befor it started bouncing. just getting my moneys worth out of em. ill get a pic befor we pull out to show everyone how to have fun!
2016 hawk
kaw h1 400 tripple
Old 07-21-2018, 08:36 PM   #14
pistolclass's Avatar
Is it possible to use a trailer hitch mount? I haul my hawk all the time with one and it is super easy. This way both wheels are off the ground. $100 from harbor freight.
Old 07-22-2018, 09:28 AM   #15
tomrom   tomrom is offline
This is the way to go. I think the type that drag the rear wheel are better suited for large heavy bikes that exceed the weight limit of the horizontal type. The harbor freight or equivalent one has a little ramp and can be used on any car with a 2 inch receiver. I just don't see any advantage to letting my bike bounce around and be subject to road hazards and wear and tear.
2017 Bashan Storm
