advice on jet size,uni jet size
I need some jets for my lifan 200 gy and what size of uni filter for my 06 and 07 lifan and i might drill out the pipe if that makes a difference thanks for the help and also put ams oil in and clutch is now slipping so i need stiffer clutch springs
First off, I am a great supporter of synthetic oil, but not till a motor is broken in completely. Chances are you will glaze up the clutches if the plates have not properly broken in.
As for jets, there is no one magic size. What is your alltitude, What is driving habit like, What is your gear ratio, what other mods are you going to do with the jet change. All these factors will make a big change in the jetting. I live at 6000'and ride to well over 7500' regularly, and even with the exhaust silencer change out, uni filter, and gear change, I am now a tad lean from the factory setting. At sea level, I would be lean to the point I would worry about burning a valve or piston.. |
thanks!
bike has already been broken in.I figured i gave enough information with putting in the uni filter and drilling out the pipe.The only thing i didn't say was that i'm about 150 feet above sea level.
I'm at about 900 feet above sea level with an open free flowing after market exhaust a K&N rc-1120 filterW/sock and had to go from a stock 98 main to a 115 just to get it to run right again.
#5 | |
