Old 04-09-2019, 03:11 PM   #1
Ariel Red Hunter's Avatar
My Qlink does this also. The first two or three stabs at the pedal are like finger nails on a chalk board...but after it heats up, the noise goes away and it becomes it's normal spongy self.
If these rear brakes are cable operated, that is where the spongy brakes are coming from. Chinese cable housings have more "give" to them than most. If you can adopt H-D/Indian brake cables to your rear brake most of the spongy feel will disappear...ARH
Old 04-10-2019, 07:56 AM   #2
Mine has drum brake with the metal rod.2LZ mine was the other way around,as it was quiet at first then after riding a bit I’d start hearing it from the rear brake...funny lil bikes
Old 04-10-2019, 10:27 AM   #3
Mine's solid rod actuated also. i just think I've been spoiled by disk brakes at this point. My drum still works fine, it's just not as sensitive.
I always said the rear drum on my old Harley was "for display purposes only". ;-) It was awful!
