Old 08-15-2019, 12:36 PM   #1
Adrenalcookie   Adrenalcookie is offline
I have purchased a chinese bike from a man across the country
So after many sleepness nights i have purchased a Boom lil duc from kronik racing, which im guessing is the same bike as the venom motorsports x21r. other than the fairings it seems to be the same bike as the vaders, So would the exhausts that you guys use for your vaders mount on the boom lil duc? Also would the stock chain fit the 17t sprocket or do i have to buy a new chain too?
Old 08-15-2019, 03:42 PM   #2
Yep, the Boom is the same Bike as the X21R and RS .The exhausts that fit Vaders should fit no problem ,it is the same engine with the same exhaust port outlet angle.
As far as the chain goes., "most" stock chains will work with the 17t swap, you just have to adjust the rear wheel as far forward as it will go. I've only known one case where the stock chain was just too short ,and even then all he did was add an extra master link .The stock chain stretches a significant amount even if properly lubed and adjusted even over the first 50-100 miles so worst case is if it is just too short when you get it, run it a hundred miles and chances are it will fit fine.
2001 Mustang GT
2004 Sportster
2018 VADER
2020 Orion RXB250L
Old 08-15-2019, 05:31 PM   #3
Whisky   Whisky is offline
Whisky's Avatar
Welcome. I have same bike just with a few mods
2018 BD125-8-x21rs
ZS190/Genuine PE28
Kepspeed GP1 Exhaust
Protaper se x110 bars/grips
1/4 MotionPro throttle
Kepspeed Braced swingarm
Chimera rear hub assy
Grom Intergrated tail light
Superlite Sprockets 17/32
custom made from Japan
Chimera Swing Arm Bolt
RK MXZ Chain #420
All Balls wheel bearings
Motodynamic fender eliminator
Coremoto ss brake lines
Composimo 2.5 lower link
Grom Calipers-w/ebc pads/rotors
Michelin tire 140&120
13x4/13x7 fatties
Grom forks
Old 08-15-2019, 08:34 PM   #4
PhildoScaggins   PhildoScaggins is offline
Lol, just a few Glad you finally got your 190 in. I feel bad, my china bikes have been gathering dust in the basement all summer while I've been riding my 89 yamaha radian. Maine registration laws are strange for cycles so I decided to wait till next spring. I have been bummed out about the lack of content here as of late, but I need to remember everyone is out riding, and I've done nothing to contribute myself.
Old 08-15-2019, 10:07 PM   #5
Do you have the link to those tank grips?
Old 08-16-2019, 01:38 AM   #6
Whisky's Avatar
I've been spending most my time on the zs forum and clone army. Yeah 190 sat in the box for 5 months. It is ALOT of fun now, we'll worth it. I will post where I got the tank grips when I get off work as I will have to look around cuz I don't remember right off hand. Don't get me wrong, the 125 is lots of fun too but the 190 let's u Cruz at a much lower rpm and having 5 gears is a big plus. The swap is really easy to do.
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 08-16-2019, 10:01 AM   #7
Thanks for the info guys, I’ve been looking at exhausts but I can’t find any bolt on high pipes, and how does the Honda Dax exhaust sound compared to the stock one?
Old 08-16-2019, 12:08 PM   #8
Whisky's Avatar
Exhaust from a Honda dax, z50, z70 are exhaust that will bolt right on to your engine. On clones the exhaust port on the head is at an angle, the exhaust port on a Honda Grom and ssr Raskull face straight down. Any aftermarket exhaust is going to be better then the restricted stock exhaust. Check motorkit.com they have several styles to choose from, I think they have a few high mount too.
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 08-16-2019, 12:38 PM   #9
Whisky's Avatar
Google Ducatti tank grip cover. Several different styles available.
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
