09-14-2019, 09:44 PM | #1 |
Grom Forks installed
That was so easy. 20 minutes tops and the Grom forks in there stock form are better then the clone forks, I didn't think they would be at 1st. I will up grade them at some point though.
2018 BD125-8-x21rs ZS190/Genuine PE28 Kepspeed GP1 Exhaust Protaper se x110 bars/grips 1/4 MotionPro throttle Kepspeed Braced swingarm Chimera rear hub assy Grom Intergrated tail light Superlite Sprockets 17/32 custom made from Japan Chimera Swing Arm Bolt RK MXZ Chain #420 All Balls wheel bearings Motodynamic fender eliminator Coremoto ss brake lines Composimo 2.5 lower link Grom Calipers-w/ebc pads/rotors Michelin tire 140&120 13x4/13x7 fatties Grom forks |
09-15-2019, 12:43 PM | #2 |
I gotta measure like you said. I want better forks too.
09-16-2019, 11:23 AM | #3 |
Could you elaborate a little on the upgrade , be nice to know if you swapped brake caliper / rotor from Grom or used stuck one, wheel / fender, etc .
09-17-2019, 02:10 PM | #5 | |
Currently I'm still using the stock calipers, ( Grom calipers not installed yet) rotors are EBC, ordered for a Grom, wheels are stock, fender stock, Grom forks do not have the stopper for the clone speed sensor but when u tighten axle it holds sensor in place. Fork mounting point measurements are top triple tree-41mm bottom triple tree -45mm
09-17-2019, 02:14 PM | #6 | |
09-17-2019, 02:22 PM | #7 |
Dam.... look at that list of mods you have!!!! and you think u need to add more??? Even had to go small font. Must be talkin to Mr. Money Bags lol
09-17-2019, 10:56 PM | #8 | |
I can not add anything more to the list. It is limited to 500 characters. Using HTML to change the font took up some of the characters too. Last edited by scoot newb; 09-18-2019 at 04:16 PM. |
09-18-2019, 03:48 AM | #9 |
Probably will need to start using abbreviations.
09-18-2019, 10:55 AM | #11 |
If u see a pair for around 250. I would grab them
09-18-2019, 03:58 PM | #12 |
Closest I found was 285 on Ebay so far. Was hoping to find better condition than that listing. Tried some forums, offerup, letgo, CL, but nothing,.... Something'll turn up hopefully
Can I ask what year grom forks you went with? I wonder if they're all the same or 14-15 different from 16,17,18,....
BD125-15 Last edited by cbrfxr67; 09-18-2019 at 04:42 PM. |
09-18-2019, 04:51 PM | #13 | |
09-18-2019, 05:27 PM | #15 |
Good tip but bad idea for me. I run across too many bikes I would like to buy.
