#31 |
The manual says 15W40 motor oil for the gear box oil.Lucas makes a synthetic 50W gear oil.A little pricey.I know,just go ahead and put 70W90 gear oil in there and be done with it.
#32 |
I had gear oil from the factory in mine. I feel it was a miss print. I think I used a mobile 1 75w90 gear oil, but I'll check tonight.
#33 |
Same here. I used synthetic 75w90 gear oil in both my ATV and UTV. Don't remember what brand right off hand.
#34 |
I picked up a bottle of Super Tech synthetic 75W90 at Wally world yesterday for $6.97,figuring if it does take something a little thinner,synthetic would be the way to go.They had some Valvoline synthetic but it was $12.47 a quart.
I got to get some kind of hitch mount welded up extending out away from the rear end so I can start pulling stuff.As is the ball mount is angled down plus it's too close to the rear axle carrier.Turning radius is severely limited if pulling some kind of cart without hitting your chain guard...etc. |
#35 |
For the hitch you could get something like this.
https://www.amazon.com/Coleman-ATV-U...gateway&sr=8-7
#36 | |
https://partskit.com/product/110316 |
#37 |
How long did shipping take? I'm on day 17 without any word of a tracking number
#38 |
tracking number
someone should send you a tracking number.. I guess your not talking to the right person... all reliable places will send you a tracking number..... it is too bad some lazy employees ruin a place for reliability... call them ask for the manager and tell him your problem.. they should give you a answer..
#39 |
Gear oil???
Why are you using gear oil in the motor for????
What Is the Difference Between 75W90 & 80W90 Gear Oil? Gear oil is used to keep gears running smoothly. It protects the gears from wear down, corrosion, oxidation and rust. for gears not engines.... use some LUCAS OIL PROTECTION OIL IF YOU WANT .. I would just use the 10-40 or 15-45 oil for warn weather... if hotter weather... a straight 40 or 50 oil... not gear oil...…. not recommend … google it.. and you see... but it is your motor
#40 | |
#41 | |
Have you already paid for it?Maybe their out of stock at the moment and are waiting on new stock to arrive. |
#42 | |
They said when I paid in full that the factory said they had them in stock. It's now day 20 |
#43 |
Who did you purchase from?
#44 |
tracking number
I hope instead of posting here.... you are bugging them every day .,.. where is my atv… where is the tracking number.... speak to the sales manager.. etc.... keep on their ass... you are not doing this right.. you should know the answer..
#45 | |
Doubtful they will ship just one... more likely a whole shipping container full of them to be broken down to all the sellers, or if this particular seller sells enough for a whole containers worth. Not sure if they get better pricing with the later... just guessing. You can always cancel the order and go with another seller. I would probably do that if they aren't giving a straight answer. |
