Hawk 250 Rear swing arm Bolt
Does anybody know the diameter of the hawk rear swing arm bolt? it's the bolt that holds the rear swingarm on, not the axle bolt. it appears to be a larger than 1/2 inch it could be 5/8 or maybe or 13 or 14 mm? None of my local hardware stores seem to have a bolt that big.TX powersports wants 45 bucks for that one bolt and I thought that was a little steep. Let me know if you have a link where I can get one cheaper?. Thank you
This. The tt250 uses a proper axle style shaft with a concave washer and a.flanged nut on each end. Much better style than a simple bolt as it eliminates a lot of torsional strain caused by the fixed bolt head. Plus you can order the whole shebang for about half of what they want for.the Hawk bolt.
2018 Hawk - Nibbi PE30, Nibbi Intake, UNI Filter, Ebay Exhaust, NGK 4929 (non-Iridium), 428 D.I.D. X-Ring, 15/40 Sprockets, Walmart AGM Battery, IMS Shifter, Full LED Lighting, Digital Cluster, CSC Swingarm Pin, Modified Chain Adjusters, Upgraded Wheel Bearings ** MPH Cruise, ** MPG |
Thanks for your comments, I will do that
