Old 10-27-2019, 08:59 AM   #31
Fonzi007   Fonzi007 is offline
Originally Posted by sshevie View Post
If you are going to put a new carb on be sure to get the pz30 pumper carb I've just put one on bike bike and it's been the best upgrade I've done.
It comes stock with a PZ30 but I have to mess with the fuel mixtures screw cause the bike itself is idling so low I know most of them come Super lean for shipping purposes but Its been registered and now the upgrades can begin!
Old 10-27-2019, 09:26 AM   #32
PROS and CONS
PROS
Bike rides smooth
Air suspension is a little stiff but the bike really does well with road and dirt (I know that some are saying off road its stiff it is but this also has to do with the preload on your bike and since Im light I dont compress on the bike as much as someone whose taller with more weight) So yes a tad bias but being honest lol!
This Bike tops off STOCK at 55-60 mph, I want to disclose that I am about 145 so Im light as hell
it handles so well on road, great traction
came with NGK spark plug
ELECTRIC start is great used the kickstart and works well
Bike is up-gradable
530 chain
Registered With NO problems in Florida !
CONS
Stock mirrors that came were not the correct fit, I ended up buying adapters 8MM to 10mm the mirrors came as a 8mm
Low Idling (Fixable)
Super Lean
Kickstand safety switch is a pain in the ass lol
I noticed when shifting gears My high beams would flash for every gear? I still have yet to figure that out
You have to adjust the bike to you're liking It came with a lot of throttle play but im not sure that is con since its easily fixable
1.6 gallon tank.
Seat is alittle stiff Im sure with time ill break it in
Old 10-31-2019, 08:16 PM   #33
everready   everready is offline
Hey Fonzi.. Aaaaaaaaaaa!
Old 11-04-2019, 11:57 AM   #34
Originally Posted by Fonzi007 View Post
Only difference is that is has no gear indicator and its in Kilometers.
Did you ever get it to change for KPH to MPH? If not try this. ..turn off key. Depress and hold right side button on display and turn on key at the same time. Keep holding until it changes. This worked on imapdog's Orion RXB 125XL. Cluster looks to be the same and may work on your bike too. Worth a try.
Old 11-06-2019, 06:27 PM   #35
Thumbs Up
hahaaaaa let motocheez do the best type of mods!!!
Old 12-18-2019, 01:16 AM   #36
All in one   All in one is offline
All in one's Avatar
Loving the apollo 250 deluxe8
Make sure you get the apollo db 36 deluxe
Get the Apollo 250 Deluxe! I happened to get it before they raised the price up, but if you wait the holidays, black friday, etc. they have sale's. It's a 2019 model made 07/19. Was fresh off boat in first real batch sent to the USA. Came no damages . The speedo was in MPH, not Kilometers.When you buy one of these street legal bikes, make sure you request your MCO or fill the website's MCO form out. Theres usually a link on their website's stating MCO Request form. I learned hard way... Rightaway disconnected the quick connect to kickstand shutoff switch. Follow wire up and you'll se the quick disconnect. Get rid of it .. Get rid of handle bars and do yourself a favor and get yourself a set of Pro Taper 7/8 handlebars (cr high bend). I got the platinum color on my black bike plastics. Goes together very nicely... I got pair of serpentine mirrors off ebay for literally 12.00 USD. Get yourself a rear shock cover from Aliexpress.com. By the way Aliexpress app or site has a lot of part's for these CB 250 Zongshen engines. Apollo db 36 deluxe comes with a CB250 engine. CB's have Overhead cam. The Hawks have the CG 250 engine, which are a push rod type. Heard they vibrate a lot more . Do not feel much vibration from the apollo's.. They are really 223cc or 229 cc. One or the other... Aliexpress.com has Everything from front sprocket covers and even exact stock replacement cover. They got whole air cooled engine gasket sets, pistons Kits etc.. last thing you'll need, but at least you'll have an idea where you can easily find parts for the low... I changed out my carb to a different PZ 30 carb and did away with choke at control and cable. I actually have a few you tube videos on YouTube. One is a walk around on my 2019 Apollo deluxe. I also have an apollo dbx 18 125. I did a lot to that. Like buy an extra set of stock tires and replaced them with irc heavy duty tubes and Michelin city grip street tires, basically made the dbx 18 street legal from scratch.
but if your interested I have a video & description of what I did to both. Just search YouTube for "all in one apollo db 36 250 walk around". The other video is " all in one changes I've made to apollo rfz 18" And few more if your able to find them. They both been great running bikes. I highly maintain and keep my things clean. I wired up headlights, taillights with pressure banjo bolts and all for working brake light on the rfz 18. Good learning bikes for people to start on also. The deluxe is one of the better looking 250 chinese bikes, in my opinion. Especially when you change them handle bars and those mirrors. I put a 16 tooth on front of deluxe and in motion of trying to find a 35 tooth 520 rear sprocket. Having hell of time finding one. All in know is that a 2003 honda cr250r rear sprocket will fit, but they dont make a 35 tooth for that model of honda. Just gonna have one custom made from rebelsprockets.com. only aluminum they make. I would not use the leaky battery they give you with bike. Ive seen on others bikes where it leaks a stains your swingarm, etc..Please do yourself another big favor and go on ebay and buy the Zipp sealed 12 volt 5.7 amp battery . For 19.99. Or you can get 2 of mighty max 12volt 5 amp for 23.99 ebay. Or you can get yourself a Fire Power lithium ion battery for 80.00, which only weigh's under 1 LB. You can also get CNC peg's which are much lighter then stock peg's. Stock peg's are heavy, but tough... the more weight you can take off this bike, the better off you'll be. I bought a Spirit beast oil dip stick for honda with a magnet on it and also put a dime sized circled magnet with open middle snug in the screen when you change oil out. Fits in snug and catches a lot of metal shavings. They say these are heavy bike's but name brand's like Honda and Kawasaki 250's, some weigh more. I did a lot of research on this type of stuff so. I will be getting a separate set of rims and tires eventually to swap on a dime notice. You could not ask for a better break-in for this 250 engine. Changed oil quite a few times during the first 350 break-in miles. Make sure ya check out the Apollo's. You'll be wanting one. Hopefully all goes well for ya folks. Have a good one. Ride smart. Here's pic few weeks after purchase.
Last edited by All in one; 12-18-2019 at 09:09 PM. Reason: Wanted to add a picture
Old 12-18-2019, 01:36 AM   #37
Duckman   Duckman is offline
Duckman's Avatar
That bike is gorgeous, wow! My buddy is looking to buy a new dual sport, I was going to steer him to the Orion RXB 250, but I must now show him this one.
Welcome aboard.
Duckman
Old 01-10-2020, 11:55 PM   #38
Audionut74   Audionut74 is offline
This bike is very tempting for my next project
Current bikes
2011 KTM 990SMR (Street Bike)
2011 KTM 990SMR (Track Bike)
2019 Wolf Rugby 150
Past Bikes
2007 KTM 950 SM
2013 KTM 690 Duke
2009 KTM 690 Duke
2009 Kawasaki KLR 650
2008 Yamaha WR250x (TURBO)
2007 BMW XMOTO650
2009 DUCATI Hypermotard 1100s
2012 GMW G150v (200cc custom)
Old 06-20-2020, 01:14 AM   #39
Atomicjoe01   Atomicjoe01 is offline
Bike does over 60 stock
PROS
Bike rides smooth
Bike is up-gradable
530 chain
CONS
Super Lean
1.6 gallon tank.
Lol idk why I keep seeing people say the bike does 55-60. Dead stock I hit 67 on mine and with all my upgrades I hit over 70 (mikuni carb jetted, air filter, Powercore 2 exhaust) I recently dropped to a 12tooth front sprocket tho for more low end power and I can still hit 60mph.
Old 01-25-2022, 10:12 PM   #40
Walt28Wood   Walt28Wood is offline
So far I love my Apollo db36 but it is very shakey at high speeds, i.e. over 45 mph. Has anyone figured out a rim swap to remove the loose wire spoke rims and replace them with some well balanced aluminum ones? I am thinking of hitting up a few motorcycle junk yards on vacation and see if any of the Honda rims would work.
apollo 250cc rx, apollodb36, db36, deluxe
