Old 01-13-2020, 12:33 PM   #31
Cool! You could install grip heaters or a USB port for charging your phone.
Love your Neil Peart reference; Canadians are in mourning.
Old 01-13-2020, 12:53 PM   #32
Landsvw   Landsvw is offline
Landsvw's Avatar
We old rockers love Rush. I saw them 2x. He wasn’t only an amazing musician but also a thoughtful amazing human. So are the other two.
Blessings
L
1988 Kawasaki KLR250
1969 Honda Z50 silver tag
2002 Ford F-350 7.3 diesel
1975 Corvette
2017 Chevy Bolt
“Throttle twisting geek” -LFN
Old 01-13-2020, 11:29 PM   #33
Landsvw's Avatar
I got my little 10$ package of wiring in! installed in easily. too cold to go further today. lets see, other than that, when i can get a few free hours I'm almost ready to crank it to see if it has spark.
also, figured out the fuel issue. the automatic (vacuum activated) tank switch was stuck closed. fixed that (looks brand new too; not a speck of corrosion).
waiting on the intakes!
1975 Corvette
2017 Chevy Bolt
Old 01-18-2020, 09:44 PM   #34
Landsvw's Avatar
reassembled carbs. stuck the new manifolds on. got the thing to putt putt and verify that electronics work, etc. ran for maybe 5-10 seconds without choke or throttle cable hooked on.
but, something choke related is missing... seems to be the cable. Will investigate tomorrow. highly encouraged by what I heard tonight tho.
1975 Corvette
2017 Chevy Bolt
Old 01-19-2020, 08:40 PM   #35
Landsvw's Avatar
Carbs 1 and 2 are leaking so am working on that. Float needles are not sealing.
1975 Corvette
2017 Chevy Bolt
Old 01-19-2020, 08:43 PM   #36
cheesy   cheesy is offline
cheesy's Avatar
Float needles or cracked float bowl overflow tubes?
Cheesy
07 Ural Gear Up
79 Honda CX500
77 VeloSolex 4600 V3
73 VeloSolex 3800
Old 01-19-2020, 08:50 PM   #37
Landsvw's Avatar
Well, I’ve got the carbs on the bench. Attaching a fuel source to them makes gas pour out the back of the carb on the right two. I’m predicting float needles are still cruddy.
1975 Corvette
2017 Chevy Bolt
Old 01-19-2020, 10:47 PM   #38
cheesy's Avatar
I predict you are correct.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 01-19-2020, 11:42 PM   #39
Landsvw's Avatar
I’m trying to ‘get away’ with not buying any carb parts... ugh... might not. Figured if it gets running decently, I’ll run some sea foam through it and cross my fingers hehehe.
1975 Corvette
2017 Chevy Bolt
Old 01-20-2020, 11:50 AM   #40
You might be able to clean the seats with a Q-tip and some carb cleaner.
Old 01-20-2020, 12:00 PM   #41
Landsvw's Avatar
Good idea! I was trying to think of how I could get down into that seat.
Wife has this tiny straw brush I was gonna borrow and return, smelling of gas... hahah!
1975 Corvette
2017 Chevy Bolt
Old 01-20-2020, 12:08 PM   #42
I use a toothbrush and carb cleaner for the needle and all of the other bits. Not my toothbrush though, that's gross.
Old 01-26-2020, 11:44 AM   #43
Landsvw's Avatar
Worked on the GS yesterday. 4 carbs is a pain in the butt. Got it reassembled and actually running for a bit. Wasn’t perfect and pretty sure I’m low on gas. Started feeling sick (our community has flu like crazy) so came inside. Airbox and carbs and throttle are on tho!
1975 Corvette
2017 Chevy Bolt
Old 01-27-2020, 11:44 AM   #44
I hope you feel better soon. Congrats on getting it running.
Old 01-28-2020, 10:54 PM   #45
Landsvw's Avatar
Still under the weather a bit. Been thinking about the bike tho. It has a prime and run on it. A vacuum fuel switch. I’m thinking if I turn it (uses a screwdriver) to prime it should fill the bowls. Then it should start!
1975 Corvette
2017 Chevy Bolt
