Old 01-28-2020, 08:09 PM   #16
SevereTrauma   SevereTrauma is offline
SevereTrauma's Avatar
Rear came in today. I installed it but it's bottoming out. I might try going with the dual rear shock that was posted where. I don't want to go back to the stock shock. It's tough on my old body.
Old 01-28-2020, 09:13 PM   #17
dragonbusa   dragonbusa is offline
I'm gonna be posting an in depth how to video tomorrow on how to do the dual shock install. Step by step. I've already made the video just gotta go up to my wife office to use the high speed internet. Mine here at the house is way to slow to upload videos. Should be up by 10:00am.
Old 01-28-2020, 09:20 PM   #18
Looks like the same ones I bought.
Old 01-28-2020, 10:15 PM   #19
I looked at your post. Just mocked everything up for the dual shock install and should be good. Need two longer bolts after work tomorrow and then I'll install. Seems pretty straight forward and I'm not the handiest guy. Hopefully they don't bottom out with two. Have you ridden yours since doing it?
Old 01-28-2020, 10:55 PM   #20
Oh yea I've done a lot of riding with it, I weight 240lbs and mine never bottoms out
Old 02-11-2020, 08:07 AM   #21
dugndeep   dugndeep is offline
How many pounds of air are you all putting in them?I bet the ride is so much smoother.What about just putting 1 shock on the back?Sorry I didn't read through all the post about just adding 1 shock.So 1 shock is not enough.
Old 02-11-2020, 08:43 AM   #22
I haven't messed with the air, it's just as it came. I haven't been able to find any recommendations on air and am not familiar enough to mess with it. The two on the rear seem nice but I haven't taken it out yet. They have to be better then stock though. I could barely move the stock rear it was so hard.
Old 02-11-2020, 09:37 AM   #23
Mudflap   Mudflap is offline
Recommendations I've found on line are about 80 psi for the RFY shocks. Hard to make it precise with such a small reservoir because you loose some pressure when you remove the air chuck feom the valve.
Old 02-11-2020, 09:41 PM   #24
I copied and pasted this for the sellers ad where I bought mine.
Factory Air Pressure: 0.4 Mpa
Maximum Air Pressure: 0.5 Mpa
