Old 03-10-2020, 07:52 PM   #1
vtwinaddicted   vtwinaddicted is offline
Doh! Brozz 250 NGK plug?
What is the correct ngk plug for my new bashan 250?
Old 03-10-2020, 08:56 PM   #2
BuffaloChinaRider   BuffaloChinaRider is offline
Many different plugs work and people have so many different opinions on plugs. I can tell you what works well on many china bikes and what works well on my Apollo db36 deluxe. Here it is below:
Actual Plug: NGK (6681) DR8EIX Iridium IX Spark Plug
BuffaloChinaRider on Youtube
Bashan Storm 250 (2018)
Apollo Db-36 Deluxe (2019)
Old 03-10-2020, 09:30 PM   #3
NGK 2202 will also work.
Old 03-10-2020, 10:40 PM   #4
gwowzer   gwowzer is offline
Is the end of that plug compatible with the "threaded" type end of the female spark plug wire? I ordered that exact plug and was just looking at it in the garage questioning if it would fit correctly
Old 03-11-2020, 12:25 PM   #5
cycleway4   cycleway4 is offline
For a simple, inexpensive, direct cross plug,...the NGK DP8EA-9 (5829) works just fine. OEM in many made-in-japan bikes over the years.
<div>Steve
2006 Roketa DB-07A/RSX-200E
2008 Roketa 250 Scooter
2019 Brozz 250
Old 03-11-2020, 04:20 PM   #6
The 2202 has a removable cap so can be use with either type.
Old 03-12-2020, 07:02 PM   #7
Thanks for all the input
Old 03-12-2020, 07:46 PM   #8
humanbeing's Avatar
Japanese NGK site had more info http://chinariders.net/showthread.ph...793#post264793
Old 03-15-2020, 05:32 PM   #9
HoneYBadger86   HoneYBadger86 is offline
Does anyone know the difference between the 5829(DP8EA-9) , and the 4929(DPR8EA-9)?
I put the "R" designated one on mine yesterday befor an all day ride, it ran just fine, but if there's a chance it might be damaging in the long run I'll need to change it asap.
