03-26-2020, 07:03 PM | #1 |
Rhino 250 chain rubbing swing arm
So I’m a complete noob to ATVs and I just got a new rhino 250. We put maybe 5 hours on it and I noticed the chain tensioner is pushing the chain into the swing arm. I’m assuming this isn’t normal. What is the normal amount of play in the chain? I understand how to adjust it (the mechanical process) but I don’t want to make it too tight and ruin anything
03-27-2020, 10:45 AM | #2 |
I have been running mine pretty tight, about a 1/4 - 1/2 inch of slack with out issues. I typically need to tighten it up after every 5 runs or so.
03-27-2020, 05:20 PM | #3 |
10mm to 20 mm movement at midpoint is the general rule, with tensioner loose.
