Old 03-30-2020, 08:04 PM   #1
Kenstogie   Kenstogie is offline
Kenstogie's Avatar
a better ground cable under $5
https://www.walmart.com/ip/Everstart...SABEgIQQ_D_BwE
after feeling my ground cable becoming warm...warmer than it should be....i knew a better ground cable was in order.....
well after a trip to wally world near the car batteries for me....
heres a better ground cable for under $5 ....you do have to cut the end with the hole thats to big and with whats left just drill out the right size and file a little bit to get rid of burrs.... 15 min job and more power...it is quite noticeable on my TBR7. the stock one is next to it for comparison.
File Type: jpg F711EFD6-34F6-4CC0-AA9E-0AA1D4DB30CA.jpg (18.6 KB, 299 views)
File Type: jpg 060F3394-82CB-4207-BD04-A00D1AE71959.jpg (20.0 KB, 293 views)
been around bikes for a while....
honda 72 cb200t, zuki 96?/2002 katana, 12 vstrom,09 vstar, kawi ltd440, 82 zuki Gs1100, Tao Tbr7
all about the Tao MotorsTBR7
http://www.chinariders.net/showthread.php?t=25553
Old 03-30-2020, 08:09 PM   #2
dossbag   dossbag is offline
dossbag's Avatar
Kinda strange it's the ground cable.. usually the live can get warm when starting.
Make sure there are no shorts, or the connections are tight. You can always "add" another ground.
2014 Bashan Storm 250 Enduro
1998 Harley Davidson Fat Boy
1993 Suzuki GSX600F - Rebuilt
1995 Harley Davidson Chopper build from ground up.
1983 Yamaha XJ900 REBUILT!
1971 Triumph Daytona 500 - Restored
1987 Yamaha FJ1200
Old 03-31-2020, 08:19 AM   #3
Kenstogie's Avatar
yea it only did that when starting and trying to restart about 3x .... connections are definitely tight now and i sprayed some NcP2 on the connections for good measure.
Old 03-31-2020, 09:58 AM   #4
I don't find it strange that the ground gets warm. On the Hawk the ground wire is no larger than a 12, and IIRC is a 14awg in size. I upgraded mine to a 6AWG pure copper ground strap with 5/16" lug ends for power inverters. It was a bit cheaper when I bought it though. Now it's up to 12 bucks for the 12" length I used (Hawk ground is on the opposite side).
Old 03-31-2020, 10:52 AM   #5
Kenstogie's Avatar
i checked the connections on the stock ground and they seemed fine but i suppose it's possible i missed something or whatever....
with the stock ground i would get 2 decent cranks while trying to start (luckily it generally does start right up ) .....then the dreaded clicking sound and dim lights.... which getting only 2cranks wasn't a big deal ....you only need 1 right? .....
wrong! it stalled when cold sometimes because i didn't hold the throttle till it warmed up a bit... or i forget to turn on the petcok or i didn't choke it correctly or whatever...
i assumed it was a mediocre battery (which it partly is) but it was also the ground....
now i get 5 or 6 and the bike starts even quicker than before... lights don't dim nearly as much.... i would also assume it will charge better and quicker now...
Old 03-31-2020, 11:02 AM   #6
Oh, word of advice/tip. Put anti-seize on the bolt for the ground strap that goes into the engine case. The galvanic corrosion is STRONG on that bolt.
Old 03-31-2020, 11:37 AM   #7
"Oh, word of advice/tip. Put anti-seize on the bolt for the ground strap that goes into the engine case. The galvanic corrosion is STRONG on that bolt."
I second that as extremely good advice- ask me how I know lmao.
2001 Mustang GT
2004 Sportster
2018 VADER
2020 Orion RXB250L
Old 03-31-2020, 02:42 PM   #8
Kenstogie's Avatar
Good Advice.... as always. Thanks Megadan!
