Old 04-10-2020, 10:19 PM   #1
dispatched   dispatched is offline
Rear shock replacement Hawk 250
Could I use this as a replacement for the rear shock on a Hawk 250? I've seen the white one that megadan put on his but the color choices on these were neat. Any input would be appreciated. Was going to go down to a 280mm shock because I'm not that big at 5'8" and 150lbs.
https://www.aliexpress.com/item/3295...archweb201603_
Old 04-10-2020, 10:32 PM   #2
No, those will not work. Those are twin shocks used on bikes with a shock on each side of the swing arm, our bikes use a single mono shock. The spring rates will be way too soft even for somebody your size.
If you truly want a 280mm shock, then I would greatly consider one of these.
https://www.amazon.com/280MM-FASTACE...omotive&sr=1-1
Or This, which is the model I Just bought for my bike to work with the Brozz swing arm.
https://www.amazon.com/FASTACE-RACIN...omotive&sr=1-1
The spring rate on my current shock is 1200lbs/in, which is much more suitable for guys well north of 200lbs, but might be a bit too firm for you. Thos shocks have a 1000lb spring. It is also of much better quality. Fast Ace stuff is some of the top end in terms of Chinese motorcycle suspension parts. The one I bought has needle bearings in the end bushings, which in itself will be a big improvement.
Are you sure you want to lower your bike upwards of, and possible more than, 4 inches?
Old 04-10-2020, 10:43 PM   #3
Gotcha
Thanks for the links! Maybe I'll go with a 300mm shock first. Ill look for a 1000lb fastace one on amazon then. Appreciate the info
Old 04-10-2020, 10:47 PM   #4
You could always try a 280mm shock. One member here runs a 290mm shock and has reported no issues, so there is a chance it may work out just fine.
Old 04-10-2020, 10:54 PM   #5
eye size
Is the eye diameter 10" or 12"? Thanks again!
Old 04-11-2020, 12:49 AM   #6
Hawk is 10mm
Old 04-11-2020, 10:11 AM   #7
Thanks!
Old 04-11-2020, 11:09 PM   #8
nij_tp   nij_tp is offline
Hi Dan what is the rating on a stock rear spring and what would you suggest for someone who has the stock swing arm on and weighs north of 200lb?
Thanks in advance.
Toys include Audi B7, running Stage 2+, S4 Brakes. My VW Vanagon is running 2.5l VVT Subaru engine, 18" AMG wheels, Porsche 944 Steering Wheel, W eekender interior. 1989 VW Vanagon Bluestar one of 2500, 1986 Honda Shadow, 2000 Suzuki Intruder, 1988 Kawasaki Voyager XII, 1976 Mercury Capri II, a bunch of Trailers including a shortened Vanagon for camping, a Sequoia and the latest addition a 2019 Hawk 250. (But dont tell the wife! ) (Latest latest addition a 1995 fwd Subaru SVX)
Old 04-11-2020, 11:22 PM   #9
Thanks in advance.
The stock spring is a half unknown. The heaviest rate is 1200lb/in, but it is a dual rate spring and the primary rate is rather soft in comparison. The only advantage of the shock I installed is that it is a single rate 1200lb spring, which is a good rate for heavier guys like us. The bigger advantage is that the spring preload is adjustable, something that the stock shock lacks, and honestly if the factory shock had preload adjustment I would not have changed it out.
As far as changing out the rear shock, there are several options. I went with the KEOGHS brand adjustable shock found on Aliexpress. They have gone up in price about 20 bucks since I bought mine, but mine has been great so far. https://www.aliexpress.com/item/3281...7%237564%23639
If I were to make a suggestion it would be to favor the shorter shock. Stock is 320mm center to center, so if you had to choose, I would suggest 310-315mm. That would make for a 1/2 to 1" drop in total ride height out back. I ordered what I thought was a 320mm, but it ended up being a 325mm which raised the back half an inch.
