04-11-2020, 05:07 PM | #16 |
Well I've been playing around with this for a few hours now. I have my chain tightness the way I want it. But nothing I do changes the fact that there's a 1/2 inch difference between the 2 sets of tires on either side. Not sure how relevant this is. I did notice when I tighten one of the side bolts that it creates slack in the opposit side bolt so when the chain was as tight as I preferred I just took up the slack in the other bolt instead of doing a turn by turn comparison.
04-11-2020, 07:46 PM | #17 |
spread
just make sure the spread is even … to 1/2 inch different... and the chain should be pretty tight .. within the 1/2 deflection.. the main thing is the spread... then you can back it off to get the chain tansion right.. … just make sure you tighten the bolts to hold everything..
04-12-2020, 01:53 PM | #18 |
For fun, I just bought one of those chain adjustment tools on Amazon.
It clamps onto your rear sprocket, and has a guide which shows you the correct alignment. I have no confidence in my ability to measure to make sure I didn't screw it up, and now I am paranoid! |
04-12-2020, 06:56 PM | #19 |
Are you talking about aligning the rear axle? I measure from the center of the axle bolt to the adjuster plate. I shoot for 1/16” difference.
