Old 04-28-2020, 04:08 PM   #346
Kingdiamond20   Kingdiamond20 is offline
Ok how much off
Old 04-28-2020, 04:16 PM   #347
Examples are My Hawk stock speedometer was 5-6 mph off. I replaced it with a more accurate digital speedometer. My X22R was 10 mph off and bought a speedometer calibrator to get it dead on accurate.
Are you still running the stock exhaust and carburetor with stock jets? If you haven't tuned it or installed a free flowing exhaust the performance will be on the low end.
Old 04-28-2020, 05:34 PM   #348
Yes it’s got stock exhaust and an stock carb parts
Old 04-28-2020, 06:45 PM   #349
Your average chinabike, regardless of who made it or what it is, is usually off about 4 to 6mph at highway speeds. Aka, if it says 60, its really doing 55ish
Old 04-28-2020, 07:21 PM   #350
So technically doing 45mph instead of 50mph
Old 04-28-2020, 08:24 PM   #351
What jets would you recommend??
Old 04-28-2020, 10:27 PM   #352
Would drilling holes around the inside of the exhaust around the baffle make any difference in performance?
Old 04-28-2020, 10:53 PM   #353
Thats the general rule, give or take a couple MPH maybe. At 50 indicated you might be doing 46 to 48. A GPS Speedo app on your phone can help you track the difference.
That depends on a lot of factors, but a good starting rule of thumb with most of these motors tends to be around a 105 main jet with no other mods at lower altitudes. Pilot jet depends on what style it has, but typically the most common sizes are 36,38, or 40. for a Keihin jet. It really helps to know your starting point to be able to make any suggestions.
Generally that can help improve flow a bit. Removing the catalysts from these bikes if often even more effective in terms of opening up their breathing.
Old 04-28-2020, 10:56 PM   #354
O ok ty sir
Old 04-28-2020, 10:58 PM   #355
How would I remove the baffle it’s got rivets on the outside and if so do the holes were the rivets were need to be covered ?
Old 09-22-2020, 03:18 PM   #356
What’s the size of the rear sprocket on the Df250rtf villain chopper???
Old 09-22-2020, 05:28 PM   #357
I’m wanting to downgrade for more top end speed
