#46 | |
Nitro, Keogh, etc I am sure they are all the same. The OEM shock soon leaked bad and me and my friends decided it's not worth it to work on the OEM shock. I got this shock because it already has the air valve and adjustable rebound. If it fails we can try to rebuild it.
BaShan BSR 250 DB-41H 2018 Red BS250GY-18D JFG Racing Exhaust . Adjustable Shock 320mm . Brozz Digital Gauge . Renthal Fat Bar . 428 17x46 Sprocket . Fender Eliminator . Wheel Truing . Fuel Tank Repair . Keihin PZ30 Main-115 Pilot-38 Needle-1Washer Fuel Mixture-1/2 BSR Chronicles - "Project leads to more projects!" Yamaha WR250R Suzuki GSX-R 600 |
#47 |
Update
Well the new shock blew up and it was oil filled goodness all over. Went through a whoop section and I hear a funny crack/pop come from the backend.. It was all pogo stick after that. A fun 25 mile ride home hopping and fingers crossed the chain didn’t pop off every time you hit a bridge crossing.
I’ll post a dissection of the guts when I get a chance. Ended up with a $59 Amazon thing with no rebound adjustment and it’s not bad. And I punished it hard last weekend with a 45mile strip mine test. Its a dirty birdy now, It’s a keeper. The 1st one was plush a little to soft for the woods. This new version keeps the rear planted better. There’s metal parts floating around the inside of the old one so I’m thinking it’s toast. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
#48 |
Ride height is stock no change. So the kick stand still works. The ends are swapped. Top is 40mm bottom is 30mm. I have a tool and die shop here so it was a quick fix in the mill. Others posted on the Amazon review section it was a drop in
#49 | |
I have had it
I have had it with this. I spend 1 day riding 3 days fixin'. Fixed 1 thing finds out 3 more items to do. Seems there is no end in sight... Contacting shock seller will see what he says... Based on past correspondence with him I am not expecting anything good.
#50 | |
#51 |
Yep.
Looks identical as you stated. The shock on my hawk did not have the adjustment colors and the shock was worn out before i bought the bike. So for longevity of this new "Stock" shock I have enough time to order the 1200 lb. And by the time it gets here I will need to install it anyways....lol. |
#52 |
After that one ride shock lost damping, bike has been in garage while I work on the frontend. (Alignment, wheel/stem bearing, fork, etc)
Finished the frontend and noticed there were some oil drips on the floor. ![]() ![]() ![]() ![]() AliExpress, out of whatever cool-aid they were drinking during the October national celebration, denied my return request. ![]() Just lucky I wasn't out riding I guess when this happened...
#53 |
Yeesh.. I haven't had a bit of trouble with the shock I got from Amazon, the ride and handling are amazing.
Also why would you fool with Aliexpress, to save maybe a couple dollars? Amazon has basically a no questions asked return policy and they send a truck to your door to pick up the item.
#54 | |
#55 | |
For now I will put the stock shock back on it and do an autopsy on this fake "Keoghs" shock. More projects! (-‸ლ) ![]()
#56 |
Sorry if I am posting too much! I feel like I am just spamming this forum!
![]() ![]() Got the shock apart myself. There were exactly zero drop of oil inside the shock. Apparently I bought an air shock without realizing it. ![]() Pulled the oil piston, popped the gas float piston out with compressed air, cleaned the shock. I used the oil piston to push gas float piston back into the shock, leave as much air space as possible, and topped off with oil (10w ATF). Thing is, I don't know if I should leave the air chamber as large as possible, leave no space and fill with more oil, or somewhere in the middle. Before I took the shock apart it has ~50psi of pressure, and a large air chamber. Any advice appreciated! I need the shock to be soft and compliant for off-road riding. This YT Vid does it pretty well. Cheers!
#57 |
Shock Adjustment
With the help of the group I figured out how to install the back shock. Im 6' and 195-200. Once I got the shock on Im now on my toes hahaha. I assume this may break in and sit down further......hopefully?
#58 |
Not sure if you every got your answer but mountain bike shocks had a special pump. Been years since I've needed one but i think it had a basketball style fill nozel. This were for down hill bikes not sure if normal mid west bike shops would have the pump.
#59 |
If you got one of the 1200lb rate spring shocks like we did, you are probably going to need to dial out some preload on that rear shock. I weigh a good 70lbs more than you and I had to actually dial back the preload as it was set from the factory it came from to get my rider sag right. That should help a little with the tippy toe situation.
#60 | |
