New Member with New Rhino 250
![]() Last edited by VeeVee; 05-14-2020 at 02:22 PM. |
One other thing that surprised me at start up was smoke coming off the exhaust pipe in front of the cylinder head. Is this normal for a first start up?
Does this let me know I have another problem? Thanks for the help on this! |
Totally normal. It's just burning off the paint on the first start up.
Thank you Mr. Hawk! That makes me feel much better.
Update! My charger made me believe the battery was charged.I got a new Schumacher trickle charger and it took 7 hours at 1.5 ampes to get a full charge. Started right up! Running good. Yes, I dumped the Wok Oil before my fist start up but put in auto 10w 40. I dumped that and now I have wet clutch 10w 40 non synthetic in it. With all I have read only here talks about the wet clutch oil. I will put in synthetic after the break in. I changed spark plug after fist start up to a NGK 7162 DR8EA and have two inch wheel spacers and swapped the rear tires. Thanks Whygostock.com. Looks like it should to me! I am very happy this morning. I will try to post pictures. I have been very nervous about this but having you all help me makes it so much better. Thank you so much!
#11 | |
Vee, Did you add wheel spacers; what exactly did you do to get the wider rear stance? If spacers, what's the hub size you use? Thanks! |
#13 |
Joe, 2 Inch spacers and swapped the rear wheels. Valve is now on the inside but still easy to get to it to fill the tire with air. Even though I like the way this looks, It is much better riding down a cotton row to stay off the stalks. They could punter a tire if you hit a good hard one with a sharp point. Also notice I removed the front "dining room table" off the front rack. Not liking that so much.
#14 | |
#15 |
Don't know. I ordered the ones from whygostock.com and they are perfect.
2020 Toa Motor Rhino 250, two inch Rear wheel spacers, NGK Spark plug, More upgrades to come! ![]() |
