Old 05-21-2020, 08:25 PM   #1
Digbyz   Digbyz is offline
Doh! new tbr7 carb problems
put a new keihin pz30 on it .it only runs with a 45 / 115 jets ,three turns out, and third slot down on the needle. Now Im at 700 ft, any thoughts ??
Old 05-21-2020, 10:25 PM   #2
Need a bit more than that, but I can tell you that 3 turns out on a 45 pilot is definitely not right. Have you checked the float height? Page 3 on this PDF, the PZ26 example of float height also applies to the PZ30's on our bikes. http://www.ccwthariders.com/uploads/...ing_manual.pdf
Assuming float height is set correctly, the next thing I would check for is that you don't have a vacuum leak. That would play hell with all of the mixture settings.
Also, what mods, if any on the bike?
Old 05-22-2020, 12:04 AM   #3
pistolclass's Avatar
Dan correct me if I'm out of touch but my hawk was shipped with tight valves and that needs ro be checked first, right?
Old 05-22-2020, 12:07 AM   #4
Also a possibility, yes.
Old 05-22-2020, 01:17 PM   #5
I have two hawks both run 40 / 110 , two turns and two washers . maybe a little lean . ive had this tbr7 for a month ,still doesn't run.
it can with a broken primary jet. had to buy a new carb .
Old 05-22-2020, 02:17 PM   #6
Ok I checked the float level .good. sprayed it down , no vac leak. The only mod is cat removed. Ok 45 / 110 jets ,third slot on needle . will not run in the middle ..
Old 05-22-2020, 08:37 PM   #7
Ok im going with 40 /110 adjust the needle up to the forth slot . Starting there again. I took the carb all apart and cleaned .Hope this works
