05-25-2020, 12:52 PM | #1 |
40 Tooth Sprocket for the CSC tt250
Does anyone know what other brand sprockets will fit the tt250? CSC sells a 45t but I was wondering if a 40t was available.
05-25-2020, 01:11 PM | #2 |
05-25-2020, 01:12 PM | #3 |
CSC just sells the same JT Sprocket that us Hawk guys use. JTR269
https://www.amazon.com/JT-Sprockets-...001AVQJEE?th=1 The only difference is they sell 4 5mm thick spacers with them and instruct you to mount them with the groove facing out to make up for the missing offset the stock sprocket has. A couple of other TT250 owners here have mounted them without the spacers and said they noticed no issue with the chain alignment.
05-25-2020, 02:16 PM | #4 | |
05-25-2020, 02:33 PM | #5 |
You can also just buy some of these guys if you want. https://www.aluminumspacers.com/spac...ole/mas16-10-5
In fact, they sell a decent variety of lengths so you could really fine tune the sprocket position if you wanted.
05-25-2020, 04:42 PM | #6 |
the sprocket and spacer from CSC is hardly marked up from bargain suppliers (30 vs 25). Get 1 sprocket with spacers and long bolts from CSC and then get the rest of your sprockets almost anywhere. Right now I have the stock 50, a 47 I had from my last TT250, and a 45 I bought from CSC. If I go 43 or 42 it may be aluminum.
05-25-2020, 05:35 PM | #7 | |
05-25-2020, 06:29 PM | #8 |
No doubt, but an AL sprocket is a fraction of the cost of aluminum rims.
05-25-2020, 07:44 PM | #9 | |
To each his own though. Like I said, I wouldn't do it myself, just my own opinion, doesn't mean I am right or you are wrong at all.
05-27-2020, 09:18 AM | #10 | |
Thanks for that information. New bikes have a learning curve. |
