Old 06-29-2020, 08:39 PM   #1
nexo   nexo is offline
nexo's Avatar
Doh! what did I do wrong OIL?
was bought used, oil inside air filter compartment, hopefully picture is viable. TBR7 2020 1600 miles, Is there any hope for me?
Old 06-29-2020, 09:05 PM   #2
SirKng   SirKng is offline
It's probably oil from the crankcase vent. Clean it out and check the oil level. It might be overfilled.
2018 SSR Motorsports XF250
Old 06-29-2020, 09:14 PM   #3
I recall a TBR7 having that happen several months ago. I think that one thing we have to do, including with the shipping oil, is to let the bike run for several minutes to get the oil nice and warm, so more of it flows out. Also, since we generally cannot get rid of all the old oil, keep an eye on refilling level. In other words, once you drain out all the old oil, don't just dump an entire quart back in because there might be too much residual oil.
Old 06-29-2020, 09:33 PM   #4
nexo's Avatar
could ,I caused this problem, by opening the gas cap and checking the level of fuel ,to make sure my fuel gauge was correct. did it affect the air pressure in the engine for the blow by into the air box? It,s never this before.
Old 06-29-2020, 10:35 PM   #5
Rocket tests   Rocket tests is offline
Rocket tests's Avatar
I've found oil in my airbox many times. I just soak it up with a rag every time I change my oil. No big deal.
During the coarse of riding, oil is of coarse going to slosh around the crankcase, sometimes a bit gets into the vent line and into the airbox regardless of a properly maintained oil level. Just clean it out once in a while otherwise it can get aspirated into the carb and foul the plug.
Old 06-30-2020, 06:12 AM   #6
franque   franque is offline
No.
It's just from being over-filled.
Old 06-30-2020, 08:17 AM   #7
kingofqueenz   kingofqueenz is offline
Apparently a known issue for TBR7 owners...
Have been told nothing to worry about, soak it up once every few months and move on.
Old 06-30-2020, 12:30 PM   #8
nexo's Avatar
TY
Thank you everybody
Old 09-12-2020, 09:43 PM   #9
Nate708   Nate708 is offline
Glad i found this post as its the exact reason i joined the forum, provided some sweet relief. I believe the PCV valve that comes on these has little to no restriction causing oil to just flow into the air box. I am swapping the engine into a Go Kart and will install a catch can as the air box will not be used.
Old 09-13-2020, 07:02 AM   #10
It's from putting too much oil in. No more than 1l of oil is necessary!!!
Old 09-13-2020, 09:52 PM   #11
aaw611   aaw611 is offline
Just vent it to the ground or atmosphere. It should be vapor only, not liquid oil. (check local laws and make sure this is legal)
