Old 07-13-2020, 05:36 PM   #1
crazythunder1968   crazythunder1968 is offline
biggest or best size mm carb
i have a 125cc with a stock pz20 carb. whats the best size or biggest mm size i can throw on this atv? the stock one has the air/fuel screw capped off. started dremmeling it out but stopped. didnt wanna ruin the carb without a backup handy and leave my kid quadless. thanks
Old 07-20-2020, 06:47 PM   #2
i went ahead and bought a vm22 26 mm carb. not knowing if it would be too powerful for my kids quad. im not a mechanic,i do construction, so im good with tools. had to snap a collar off the old throttle cover that was holding the cable in. the old cover didnt fit the new carb. oh well. got that done. installed carb but had to cut a few bolts to length and find the right nuts to mount it. luckily i have access to all that. done. carb installed. put a little gas in tank and it starts pouring out of the air intake. ???? now im pissed. i know i didnt put the intake gasket on backwards because the holes dont line up. i did that on his old carb and gas leaked everywhere. i hooked the gas line up to the same tube that the carb came with attached. took apart and checked needle slide was sitting correctly. grrrr it was. without knowing too much i hooked the gasline to the other tube to the right of the one i used. yay!! it worked. but bogged like shit at beginning throttle, ran good on wot. took apart again and saw the needle collar was placed on the middle setting of needle. moved it to the top and that did the trick. what an improvement. i have a 12 tooth front sprocket. with the factory pz22 i didnt notice a huge increase in hill climbing ability etc, just a little improvement. and that brought my top speed down to around 25mph. with this carb i clocked in at 31 today. i also added some cheap but nice mirrors to my boys quad. i think im done upgrading it. ordering myself a trailmaster mb200-2 in a couple weeks. i wont be touchin the quad at all.
Old 07-20-2020, 08:28 PM   #3
dirtbkr188's Avatar
Without a clamp to secure that air filter to the carb, you'll have an air leak and the quad may run extra hot, especially since you lowered the needle all the way down by moving the clip to the top notch, leaning it out even further.
Old 07-20-2020, 08:53 PM   #4
air cooled runs hot anyways and i had gas on me and was getting frustrated until i figured out my mistakes. the boot fits snug but i have the clamp and will install it just incase. thanks.
