Hawk 250 shifter position switch
Does anyone know where I can source a shifter position switch for a Hawk 250? I upgraded to the digital cluster, and 4th and 5th do not show up. It worked fine, for a while, although 4th has never worked.
Earth the wires to see if it’s not those
I may have 1 is it 1 or 2 bolt style? |
I did, and they still didn't light up in the cluster. It is the two bolt style.
If the indicator didn't light up when you grounded the wires then it would likely be an open circuit between the indicator light and the switch.
