I havent done it yet but im thinking of using
one for a water proof usb charger attached up front by gauges for charging phone last thing you want is for your phone to die out in middle of no where when your have mechanical problems with bike or on long trips and using gps on it. second i think im gonna use it to power an air compressor under my seat so i can easily and quickly lower and raise my tire pressure at will for off road and highway driving
----------------------------------------------------- "Take it easy, if its easy take it twice" 2015 CSC TT250 -Ebay exhaust -Exhaust wrap -Wingsmoto Air bent filter (POD) -Outerwears prefilter for POD -CSC jets 115 and 40 -15 weight front fork oil -47 tooth JTR269.47 rear sprocket -JT 428 HDR (128 link) Heavy Duty Drive Chain -LED tail light bulb -Auxbeam LEDF-S2 headlight bulb -Brush hand guards -30L removable tail box (ebay) -3.1amp waterproof usb charger |
The plug is arriving tomorrow
#4 | |
2018 CSC TT 250 Suzuki DR 650 2003 Honda Shadow 750 (sold and I miss it) |
This is the one i purchased. It has great reviews but unfortunately i cant give my personal opinion yet on it as it will be arriving in the mail tomorrow.
https://www.amazon.com/MOTOPOWER-MP0...cycle+Dual+USB
Air compressor mod for aux switch
Here is detailed pics of aux switch #2 hooked up to a semi permanent air compressor. so now no matter where i am i can deflate, inflate, fix a flat and even help other riders if they need a compressor. and best thing is i dont have to get it out and hook it up its ready to go with a flip of a switch. first thing i did even before the compressor mod was to upgrade to a pod filter and that freed up my airbox to be used as something else. I epoxied a cap to the hole from where the intake pipe was attached. Then removed filter after that i added a slime 40001 motorcycle tire inflator which just happens to fit right in place of filter. Then screw top back on after fishing the inflator hose and power cord threw top opening. clipped the long power wire and attached better waterproof connectors to aux wire. The hose itself wasnt long enough to reach the wheels so i added a hose extender. to make it even easier i added a quick attach tip and added an adapter to fit the hose to the connector. (i also ordered a inline pressure gauge from china but hasnt arrived yet. below are pics and links to where i got them. Oh ya and my daughter Piper makes an appearance in a pic always trying to help daddy out
here is video of set up
Excellent idea!
![]() I carry a bicycle hand pump in my burrito tube. I'm not sure weather to convert my air box into storage or pipe my pod filter and relocate it in the air box. I'm leaning towards storage space. My burrito tube is full and need more storage space. The last time I went to the spillway, even with all the mud and rain the filter stayed clean and dry.
I went with this waterproof dual USB charger/voltmeter from Amazon:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Wired directly to the battery (the charger has its own on/off switch). Works great and it's nice to see the output voltage from the battery.
2018 RPS Hawk 250cc Mods so far: 1. Mikuni VM26 Carburetor w/#115 main jet 2. 17T/45T JT sprockets 3. JT 428 X-ring chain 4. Air box mod 5. Hawk Digital Cluster 6. Aftermarket IMS shift lever 7. Performance Aftermarket Exhaust 8. 295mm Nitrogen Gas Monoshock, 20W oil front forks |
My inline digital pressure gauge arrived and instead of adding it to the end of the line where it attaches to tire valve. I installed it directly after the compressor hose end so it sits stationary under the seat so i can stand and look at pressure and easily kill the switch instead of being down on the ground reading pressure and having to jump up and hit switch when desired pressure is reached i think this is gonna work great. I dont screw down my seat either by the way usually and if i do its only one side and i have a butterfly screw that i use so its quick easy access to under my seat. I did end up using aux switch #1 for usb charging. i originally had it as a constant charge so if i need to i can have my phone charging while im not around my bike. but i have noticed it does have a slight drain and if i dont ride for a few days i might have to kick start it because battery is too low. Now i dont have the correct size battery its slightly smaller but i never had an issue with battery draining before i added the usb ports. so to make sure its not draining while sitting i just plugged it into aux #1
BUMP
just wanted to revive this thread to see what people have been doing
#13 |
The plugs are from what would have been park light n main light but due to USA regulations they moded them for outputs rather then turning lights on
I strongly suggest only light power draw/amps so the single power wire doesn’t melt. They can also be used to trigger a relay for larger things etc like bigger lights etc |
#14 |
I run a stereo system 100watt pyle from walmart
04 flywing 150 05 flywing 150 07 gasgas ec200 18 csc tt250 / foam filter mod, amazon exhaust, mikunki carb, 47tooth sprocket, o ring chain, stereo system, amsoil oil, honda 10w fork oil, tusk bars and brush guards.... more to come |
#15 |
Wow its been a minute guys got my tt250 still but broke my hip this summer. Glad to see all these cool ideas. I might steal that compressor idea as a project over the winter.
