Old 01-18-2021, 06:53 PM   #1
Browndog   Browndog is offline
2020 Brozz recon electrical issue
2020 Brozz, less than 80 miles. Had it parked under the carport for a couple of days, went to start it and the battery was cranking slow. Turned the key off and it continued to crank (dash didn't power up, key off). Disconnected battery, charged it and now when I go to hook up the battery (key off/out) starter engages immediately. Anyone had something similar happen?
Old 01-18-2021, 07:20 PM   #2
Haven't had that same issue but try disconnecting the remote start and see if that helps
2024 Zuma Storm 150 DLX
2019 Beta 430 RRS
Old 01-18-2021, 08:40 PM   #3
Yeah, if it isn't something weird with that stupid remote start they come with, then give the starter solenoid/relay a good thump or two.
Old 01-19-2021, 04:15 AM   #4
Thanks for the advice. I'm going to pull that remote start off this evening. I didn't see a sticky for the remote start removal but fairly painless? Thanks again
Old 01-19-2021, 11:16 AM   #5
BuffaloChinaRider   BuffaloChinaRider is offline
My remote receiver and alarm was right under the seat. I just took it off The seat and separate the device. You can either do that or just don't use the key fob at all. Either way solves the annoying issues.
BuffaloChinaRider on Youtube
Bashan Storm 250 (2018)
Apollo Db-36 Deluxe (2019)
Old 01-19-2021, 05:52 PM   #6
Got the remote start removed and smacked the solenoid. Started right up but took me some sluething to figure out the seat bolts were under the rear fender!
Old 01-21-2021, 07:16 PM   #7
Ok, went riding today and went shut it off, dash powered off and it stayed running. Choked it out and disconnected battery. Any body wire in a kill switch or ideas?
Old 01-22-2021, 05:35 PM   #8
paulsstag   paulsstag is offline
When i removed the remote start on my 2020 Brozz Recon you have to connect the black and the black/white wire to each other. If you did not do this then it will act as yours is doing.
Go back in , connect the two wires and see if that fixes the problem. Let us know.
Old 01-28-2021, 03:48 PM   #9
Fixed it! Thanks for the lead!
