01-25-2021, 04:45 PM | #1 |
Hawk 250 rusting after a month
Anyone have some recommendations on fixing this? My bike is kept in a shed not fully closed off but it has a roof and my exhaust is already rusting nothing bad but it's spreading fast.
https://i.imgur.com/1Sa1Qqf.png It's hard to see in the picture but it has a good 3 inches of surface rust easy fix but I'm looking for some type of coating to prevent it.
Removed Last edited by Jimmie; 01-25-2021 at 05:54 PM. |
01-25-2021, 05:14 PM | #2 |
I can't tell from the picture what I'm even looking at. Rust comes off chrome like nothing with steel wool. If it's a painted surface then clean and repainting is best. I would never clear coat chrome as it's dead easy to clean.
Electrician & Electronics Tech 2014 Honda CB500XA 2016 CSC TT250 1976 Honda CJ360T 2022 Honda Navi |
01-25-2021, 05:31 PM | #3 |
That just means its time for a performance full exhaust
01-26-2021, 11:31 AM | #4 |
The week after I got my Hawk I removed the exhaust and removed the catalytic converter, welded the pipe back together, then repainted it with Rustoleum 5000*F flat black engine paint. I put three coats on and it has worked like a champ in avoiding rust thus far. Perhaps you could do the same?
01-26-2021, 02:35 PM | #5 | |
I've done the same on all my bikes. The manufacturers paint burns off quick.
01-26-2021, 05:20 PM | #7 | |
The one thing that is guaranteed to last is usually the engine, although there are still the occasional QC rejects that got missed from time to time, usually in the form of a valve head breaking off of the stem - seen 3 or 4 of those on here in the last few years.
01-26-2021, 06:01 PM | #8 | |
Removed |
01-26-2021, 06:17 PM | #9 | |
As far as your exhaust rusting, very normal. As the rest of the guys said, just take it off, clean it up and give it a proper high temp paint job. You could even go all out and prime it too. It will still eventually need a re-coat at some point, but it will hold up a lot better than the factory paint they put on there.
