Old 05-16-2021, 06:49 PM   #1
Thumbs Up
Originally Posted by TxTaoRider View Post
Yes. It measures 8.0" not including compressing the top out spring, so the 8.5"-8.6" that honda specs (depending on source material) is about right including their travel added. The new damper tubes measured about 1.5" (actually 1.45") longer than the factory dampers.
In theory, since it's over 20% in additional travel, you can go 20% less in spring pressure with the same bottoming resistance.
That would definitely make it a better off.road bike. Not sure if I will be doing this particular upgrade, but it is pretty sweet. I like seeing other people do mad scientist experiments
Old 05-16-2021, 06:57 PM   #2
Also, damping rod is part number 51440-446-003
This does not include any other parts, but many of the missing bits can be transered from the hawk anyway.
Old 05-16-2021, 07:15 PM   #3
TxTaoRider   TxTaoRider is offline
I think the stock chinese springs may bind before full travel so you might be better of getting the whole assembly with springs.
Fyi, if you can find 1983 cr80r damper rods, they'll go about 8.9" travel. They are super rare and out of production. Also I think adding that much length to these forks may make them feel real flexy.
2021 Tao Tbr7 - "Lucille"
Mods so far- Brozz swingarm, 21" front rim (Bridgestone Tw302 rear/Dunlop D606 front tires), Digital gauge cluster, pz30b pumper carb, after market hand guards, aftermarket brake and clutch levers, round fold away mirrors, Fly handlebars shortened slightly, 13t front sprocket
2009 Q-link Legacy 250
1982 Suzuki GS1100ES - "Jolene"
Old 05-16-2021, 08:18 PM   #4
Fyi, if you can find 1983 cr80r damper rods, they'll go about 9.5" travel. They are super rare and out of production. Also I think adding that much length to these forks may make them feel real flexy.
I would get some custom single rate springs at that point anyway. Only runs about 150 bucks
Old 05-16-2021, 08:26 PM   #5
At 190lbs using the single lower spring is pretty close based on Racetech's preload/sag measurements for an MX style bike. I'm sure its be fine for someone a heavier that doesn't do many bigger jumps and besides, they were included in the the price of the forks. Lol
Old 05-16-2021, 07:02 PM   #6
It puts the bike forks up to 1980 technology. Lol
What is nice, is the parts are cheap on ebay, and if someone wanted to do the swap it could be done without having to remove the seals. In fact it could be done on the bike with a good magnet, but might be a little messy.
This summer I'll try relocating bolt holes in the swingarm along with a heavier spring to gain some travel there too.
