Old 05-18-2021, 07:07 PM   #1
Vlion   Vlion is offline
Need serious help
So a few weeks ago the throttle on my 200cc 06 loncine atv got stuck. It ran like a screaming banshee for about 5-8 min untill I could get it to shut off. Now I can't get it to spark. I have changed everything from the stator to the spark plug and everything in between , ignitor switch, spark plug coil everything and im still not getting spark.. I have torn apart the harness to make sure I don't have a ground issue everything looks fine. The bike is turning over it just wint give me spark and I dint know what else to do. Any advice or help would be appreciated. I wanted to give this quad to my daughter for her birthday next Monday.
Old 05-19-2021, 08:40 AM   #2
freezerboy   freezerboy is offline
Does it have a kill switch?
Old 05-19-2021, 04:35 PM   #3
Check kill switch as freezerboy stated. Both of mine will turn over with no spark with the switch flipped. Most need one of the brakes on. Some need it to be in neutral also. My Rhino can have either brake engaged to start but the 125cc needs the rear on. I found one of the rear brake switch wires worn preventing the 125cc from starting a while ago. Make sure those activate correctly. Both can be bypassed with a jumper to check for spark.
2012 Kawasaki Versys
1984 Honda Magna V65
2016 Rhino 250
2016 Tao Tao 125D
