Old 10-26-2021, 02:37 AM   #1
muhoboy   muhoboy is offline
muhoboy's Avatar
Installation of additional tanks for gasoline.
For long journeys to wild places far from civilization. There is a need for a supply of fuel and water. It was decided to install two tanks: one for fuel, the other for water. In the initial version, a bracket was made for attaching tanks to the rear, on the sides of the upper wardrobe trunk. This option turned out to be a failure. The center of gravity went up and the front axle of the motorcycle was unloaded, this had a very negative effect on off-road handling.
In the final version, he moved the tanks outward to the protective arches, and secured the luggage at the back.
The front and rear axle loads are now evenly loaded. The handling has become good.
First option.
Old 10-26-2021, 04:22 AM   #2
muhoboy's Avatar
The final version.
Old 10-26-2021, 08:22 AM   #3
Nice set up.
Old 10-26-2021, 08:38 AM   #4
Working_ZS   Working_ZS is offline
I'm guessing that you moved the auxiliary tanks to the front to improve the front to rear weight distribution; having them fastened to the underside of the top case mount would definitely not be good for handling, especially when full of fuel or water.
Old 10-26-2021, 08:48 AM   #5
muhoboy's Avatar
Working_ZS you are absolutely right. Now there are tanks in front, and cargo in the back. The result is excellent weight distribution and controllability.
Old 10-26-2021, 09:09 AM   #6
TominMO   TominMO is offline
Also, removing weight from the rear lowers the stress on the subframe, if your bike has one instead of a full length one-piece frame. All that bouncing offroad will cause excessive stress, especially with the weight that far back.
2021 Lifan Xpect--sold
2022 Lifan KPX
1972 Honda CT90--The Carrot
1969 Honda CT90--The Tomahto
Cheesy is the WDK (workplace drama king). Now retired. Nope, back in the saddle. Nope, finally retired.
Old 10-26-2021, 10:48 AM   #7
braindead0   braindead0 is offline
Yikes, I would not want a fuel tank sticking out like that without some protection.
I would have tried to tuck them in above the passenger pegs, just in front of the cases, that would distribute the weight better (IMO), and protect the cans from damage.
Of course if you're carrying a passenger, that wouldn't work.
Old 10-28-2021, 05:09 AM   #8
Oh well, I guess I'll be the first to ask it: isn't one of those tanks supposed to be white?
2012 Kawasaki Versys
1984 Honda Magna V65
2016 Rhino 250
2016 Tao Tao 125D
Old 10-28-2021, 08:48 AM   #9
Probably, I'm assuming OP knows to check before taking a drink or filling tank ;-)
Old 10-28-2021, 12:50 PM   #10
muhoboy's Avatar
There was a case, I confused it once. Then I didn't smoke for two days, I was afraid ;-)
Old 10-28-2021, 01:18 PM   #11
Old 10-28-2021, 03:05 PM   #12
Wink
Options....
2016 Rhino 250
2016 Tao Tao 125D
