03-06-2022, 04:41 PM | #1 |
Hawk shifter seal installation
I have a question about the best way to go about properly installing a Hawk 250 shifter seal. I watched several online videos, replaced the seal, and it leaked. I spoke with a friend of mine who is a motorcycle mechanic, and he said to use a thin coating of black RTV around the outer diameter of the seal before installing. He also noted to thoroughly clean out the shifter seal cavity with brake parts cleaner and make sure it was a clean, dry surface. I did all of that and it is still leaking around the outer diameter at the bottom of the seal, which indicates to me that I didn’t properly install it.
I’m open to any advice from those with experience successfully replacing these seals as to the best process you’ve found so that they don’t leak. Thanks |
03-06-2022, 05:32 PM | #2 | |
03-06-2022, 06:52 PM | #3 |
1. Yes, case is slightly marred from the seal being removed where the screw I used to take the seal out nicked the case. The nick is more toward the outer edge of the case, but it still could create a valley for leakage.
2. I drained the bike completely of oil, then after removing the seal, did the clean up/drying job in order to have a dry mating surface. I did *not* tilt the bike to the right overnight after reinstalling the seal with the RTV sealant. I did allow it to dry/set up for 24 hours before re-adding fresh oil. |
03-06-2022, 07:27 PM | #4 | |
If it is too hard to get your finger in there, you could use a pipe cleaner, Q-tip, etc.
2021 Lifan Xpect--sold 2022 Lifan KPX 1972 Honda CT90--The Carrot 1969 Honda CT90--The Tomahto Cheesy is the WDK (workplace drama king). Now retired. Nope, back in the saddle. Nope, finally retired. Climate: The Movie https://www.youtube.com/watch?v=A24fWmNA6lM How our government really works https://www.youtube.com/watch?v=QjadCd0VRBw Question all authority.....think for yourself |
03-06-2022, 10:52 PM | #5 |
Try cleaning up the burrs and get the area clean and dry of oil. Then apply a little Permatex "The Right Stuff" (black) around the outside of the seal then install the seal. Let it dry a few minutes and go have fun. That stuff is impervious to oil and thick enough to seal up imperfections.
Also check your vent hose for blockage, as that can cause the crankcase to build enough pressure to make oil leak from the seals.
03-07-2022, 09:12 AM | #6 |
Thank you. Good idea on the vent hose. I did not think of that. I did use Permatex on the seal originally, but I will definitely check the vent hose.
03-07-2022, 09:14 AM | #7 |
Thank you. The little nick in the case could literally be filled in with a little dab of JB Weld on it on the end of a toothpick. That is how small the nick is. I didn't think it would leak with that nick being so small, being at the outer edge of the case, and with also using RTV sealant. Obviously, I was wrong and any imperfections in the sealing surface can lead to this.
