03-13-2022, 10:53 PM | #16 |
Thanks. Great video but how on earth did you get your torque wrench on the top fork pinch bolt?
03-14-2022, 11:08 AM | #17 |
Thanks for the post. You referenced some torque specs which I hope I captured correctly:
Upper fork clamps - 17ft/lbs Lower fork clamps - 25ft/lbs Front brake caliper mtg bolts - 22ft/lbs Front axle bolt - 35ft/lbs What is common torque being used for the rear axle? Would the rear caliper mtg bolts also be 22ft/lbs?
2021 TBR7D 17 front, 42 rear PZ30 Clone Milwaukee, WI |
03-14-2022, 02:01 PM | #18 |
I mean how did you get the torque wrench to fit on it to torque them? There's not enough room.
