Old 03-08-2021, 11:51 PM   #31
NinjaSICKthirtysix   NinjaSICKthirtysix is offline
Make sure when you resize that its under 195k i believe is the limit for jpeg..
No matter what I do it keeps saying too big. Dont know why.
Old 03-09-2021, 12:58 AM   #32
Use an image hosting site like imgbb.com (what I use). You can upload there and then post to the thread using the "Insert image" option in the top tool bar, and then simply copy and past the direct links.
Old 03-09-2021, 01:19 PM   #33
RussellTA   RussellTA is offline
RussellTA's Avatar
I found an app for my iPhone called ‘compress’. With that I can adjust the pic size down to about 40% and get to the <195kb
TR
As you travel down the road of life, keep your eye upon the donut, not upon the hole
2020 Lifan X-Pect 200efi
2005 Harley Davidson Sportster XL1200R
Old 03-09-2021, 02:20 PM   #34
TR
Might try it on a computer if you can. Select the picture, right click, then select resize and "S"
Old 03-09-2021, 04:45 PM   #35
That's what I now use, after asking idle purr about posting pics. You can resize the pictures right on the sight by hitting the edit (pencil icon) .All you need to do is set the width at 750, submit, upload, and copy the bb medium code, and paste them in your post on this forum. I know that you already know how MegaDan, but I figured that it may help those ,who like me, are not real good at computers, and phones.
Old 04-24-2022, 10:20 PM   #36
Magician X-pect riding
First good day for riding in since I think winter began. Least I could get out in. Did some break in on the X-pect 30 miles and that felt so good I had to take Magi out and do the same course! These bikes remind me of each other, not how they look but how they ride! CG strong, ride hard!
Old 05-03-2022, 01:52 PM   #37
landshark   landshark is offline
First attempt at posting pics. Let's see if it works.
Old 05-03-2022, 02:49 PM   #38
Nice looking bike! Good job on the PIX and the exhaust. You should do a right up on how you did that exhaust!
Old 05-03-2022, 03:51 PM   #39
Sport Rider's Avatar
way back in early 2016 after getting it all put together. One of the first times I treated it the way it deserves.
File Type: jpg PART_1456511286114_IMG_20160226_132735.jpg (127.4 KB, 158 views)
File Type: jpg PART_1456511302082_IMG_20160226_132723.jpg (148.5 KB, 171 views)
File Type: jpg PART_1456511320337_IMG_20160226_132713.jpg (145.0 KB, 179 views)
Old 05-03-2022, 11:01 PM   #40
I ride in a few different areas... pipeline ways, abandoned frontage roads, future home construction sites, etc. The storm has comfortable ergonomics and easy controls. The Tusk DSport rear tire makes trail riding easier!
Rutted dry clay treachery!
Entrance to the trail- it is a heads-up!
Old 05-04-2022, 07:48 AM   #41
Thanks. I cut the muffler mounting bracket off the frame and drilled a new hole in the aluminum mounting tab on the muffler. There was a pre-existing hole near the original muffler mount that I cut off that lined up pretty well with the newly drilled muffler mounting tab. As you can see in the pic, I cut out the plastic to allow the muffler to fit underneath everything.
I hammered a little flat spot on the pipe for clutch cable clearance and used a little heat wrap which I really don't think I needed.
The biggest pain was drilling the hole in the stainless for the O2 sensor bung. I drilled a small hole with a bit and then enlarged it with a rubber wheel in a dremel. I cleaned up the weld a little with this as well.
The whole thing fit with very little "persuasion."
I also hacked off the rear fender.
Old 05-04-2022, 12:05 PM   #42
Q, in all her glory.
Old 05-04-2022, 01:05 PM   #43
My Black Beauty.
Old 05-05-2022, 12:31 AM   #44
My Black Beauty.
There's just something so damn lovable about these bikes. It's like that girlfriend in high school who may have not been the prettiest, or the most popular....but they always tried the hardest and never let you down!
Old 05-05-2022, 07:34 AM   #45
So true! Or maybe just a cheap date. Yeah this one is kind of hard to let go. Lots of time spent fixin her up just like I want it. 30-40 yeas from now she'll be one of those old barn finds because she's at her final resting place.
