Old 05-22-2022, 10:06 AM   #16
herbie   herbie is offline
Time to do the intake valve first, the clearance is supposed to .08mm and mine was spot on.
2022 Venom KPR 200 Red- the fastest color
16t and 46t sprockets, NGK Iridium CPR8EAIX-9, aftermarket full exhaust system. Top speed 81GPS
2023 Venom SS3 KP mini 150– Nibbi carb, Nibbi air filter, aftermarket muffler, decat
2022 Venom Ghost chopper 250
1997 Honda GL1500 Goldwing
1978 Kawasaki KL250
https://youtube.com/@herbiesgarage681
Old 05-22-2022, 10:09 AM   #17
Next is exhaust, you have to move the radiator out of the way to access the service port. To move the radiator remove one bolt at the top and lift it up to clear the 2 pins out of the holes. Valve clearance is supposed to be .12mm and mine had almost nothing so I adjusted it to proper specs.
1978 Kawasaki KL250
Old 05-22-2022, 10:11 AM   #18
Here's a pic of the timing port
1978 Kawasaki KL250
Old 05-23-2022, 04:26 PM   #19
Just got back from a nice 150 mile ride. It was such a beautiful day today, sunny and 65 degrees with a slight breeze. I believe after the cat gutting job I have a little more top end power but time will tell. I'm thinking of doing a baffelectomy next. I'm not sure though because I like it quiet but I think it will help with the exhaust flow.
1978 Kawasaki KL250
Old 05-28-2022, 05:05 PM   #20
Bar end Mirrors
The one bad thing for me about the KPR is the mirrors, when I have my riding gear on all I can see is my arms and nothing behind me. So I bought these bar end mirrors from Amazon for $23 https://www.amazon.com/dp/B07FCCJR87...roduct_details and they work great, I can see everything behind me now. I scrapped the supplied bolt and tension plug and I am going to install the mirrors with the weights attached. To do that you need a 1/2" piece of 3/16" vacuum hose and you can reuse the original bolt or....
1978 Kawasaki KL250
Old 05-28-2022, 05:07 PM   #21
Buy a little bit longer bolt to give you more threads for security. This is the bolt you will need
1978 Kawasaki KL250
Old 05-28-2022, 05:10 PM   #22
Put the vacuum hose into the hole and it will look like this. See the bolt by my finger with the cap nut on it. I turned it around so the nut is facing like this so that the bar end weight will fit in there
1978 Kawasaki KL250
Old 05-28-2022, 05:14 PM   #23
Then I took the bike to breakfast this morning, 3 hours later and about 135 miles I made it back home, I just wanted to ride all day!
1978 Kawasaki KL250
Old 05-28-2022, 05:14 PM   #24
One more pic
1978 Kawasaki KL250
Old 05-28-2022, 05:21 PM   #25
I guess I should have included the final product
1978 Kawasaki KL250
Old 05-28-2022, 05:35 PM   #26
Mad
I like the bar end mirrors. I did my 150 miles yesterday and last night.
Old 05-28-2022, 09:04 PM   #27
Falkon45's Avatar
The glass fell out of one of my mirrors a couple weeks ago. Lol. But, for $25, I'm not mad.
Old 05-29-2022, 09:30 AM   #28
What bike did you have them mounted on? The KPR200 has very little vibration on the handlebars and the rubber around the bolt should help isolate it even more. Time will tell
1978 Kawasaki KL250
Old 05-29-2022, 11:55 AM   #29
Falkon45's Avatar
My kpm 200. But, I also swapped handlebars also. Vibrating wise, it's my second roughest bike, behind my RC390
Old 05-29-2022, 05:13 PM   #30
baffelectomy
I used my drill an extension and bits
1978 Kawasaki KL250
