The shock consists of the spring and the piston, and your piston is a type filled with hydraulic oil. The seals on the piston are shot and leaking.
Your options are: 1. Take it all apart and replace the seals in the piston, then fill it back up. 2. Measure the one you have and replace it entirely. 3. It is hard to tell from the photo, but it looks like the bracket the shock bolts into snapped off, and you or a welder will need to fabricate a new bracket and weld it on. Option 2 is the best IMO since hunting down seals for it might be a lot of trouble. If it's totally disconnected and you can find seals, it will be a lot cheaper and you don't have to deal with compressing it for removal, but I still think replacement is a better decision. You can find a lot of variety on Ebay and Amazon starting from around $25, and it will be superior to something made in China X years ago. You will have air and hydraulic to choose from, research the differences and decide for yourself. My shocks are stock Chinese Pentora, but they're still very nice for what they are. Far superior to what is on my X-Motos dirt bike, granted it has a BMW fork and suspension. When it comes to pulling ATV and dirtbike shocks, they can spear out at you if not compressed with the proper device, but I have done it crudely in the past and it's thrusting away was loud and scary but, posed no obvious danger on mine. |
gio, gio beast, shock, shock linkage |
