Old 08-13-2022, 01:31 PM   #526
Thumbs Up did it
Could not resist. The sale is $50 less than I paid for my awesome original Templar X. So I have a spare 5 speed version, for now!!
Old 08-13-2022, 02:29 PM   #527
rider1010   rider1010 is offline
upgrades
Has anyone installed a new carb, air filter and or exhaust? if so what kind and what jetting for carb?
thanks
Old 08-13-2022, 02:33 PM   #528
upgrades
Has anyone installed a new carb, air filter and or exhaust on Templar 250x? if so what kind and what jetting for carb?
thanks
Old 08-13-2022, 03:28 PM   #529
thanks
exhaust:
https://www.chinariders.net/showpost...&postcount=523
Old 08-13-2022, 04:18 PM   #530
upgrades
Hey Thumper have you installed a new carb or jetting? what size is good for jetting? 125 main/45 pilot? what exhaust or ir filter do you run
Old 08-13-2022, 04:41 PM   #531
Rejet only. It came with a smoothbore as described in this thread for jetting info (Video and Pics section), so I wasn't about to buy a new carb!! Look about 13-14 pics down into this thread:
https://www.chinariders.net/showpost...43&postcount=1
I think these settings (125/45) are working (with minor needle shim).
Old 08-13-2022, 05:06 PM   #532
New carb isn’t really worth doing.
Old 08-13-2022, 05:08 PM   #533
If I hadn’t bought this I’d be all over the 6 speed X…I might say screw jr and but one anyway lol
Old 08-14-2022, 05:44 AM   #534
Blueridge boyieee   Blueridge boyieee is offline
Thumper, congrats on the bike. I’m still on the fence but mama ain’t digging a bike purchase every quarter. Between mama mentioning sanctions and the amount of work and mods done on my base, it’ll have to wait until at least October.
I’m still really enjoying the base model light weight. Seems the X has five extra inches of wheelbase and seven inches more length.
On the exhaust, I used this https://www.orionpowersports.com/sta...-249cc-engine/
It doesn’t fit the base model and it requires some cutting and welding. I think it would fit the longer X model better but the stock muffler is narrow, the clutch linkage is close and so is the rear shock (it must be a hassle removing the carb with the adjustable rear shock). The benefits are a larger header pipe diameter and no cat.
It would be easier to modify the existing pipe, some gents on here cut a rectangular opening on the cat bulb, scrape out innards and weld it back. That’s probably the better way to go.
The new 6speed has a larger muffler and the right rear plastic appears to kick out for additional clearance. And a larger fuel tank, and alloy rims, and a case guard, and a rear rack. I’m hoping Thumper will post pics of the new model when it lands. A few pics of the new hardware and reports of the 6th click and RPM drop should be enough to push me over the fence.
Old 08-14-2022, 06:05 AM   #535
Okie, that looks like a INT650, congrats. I looked at a RE Himalayan before finding the Templar. Here’s my day tripper
File Type: jpeg E2E26E0A-01EC-42A3-81A6-ED48FE73C960.jpeg (41.0 KB, 524 views)
Old 08-14-2022, 06:33 AM   #536
Thumper, I don’t know if I’m going to be able to take the two weeks for pics…
In the meantime, I’ll sacrifice a bit more grey matter.
File Type: jpeg 2C8AA6D5-5963-4FFA-B895-FAE6E77C3E4C.jpeg (18.8 KB, 514 views)
File Type: jpeg 919D078F-7695-4819-BE24-16F61DC37553.jpeg (21.1 KB, 532 views)
Old 08-14-2022, 11:12 PM   #537
Very interested in the 6 speed. Looking forward to some real data on the actual gearing ratios and vibration difference. Keep us posted!
Old 08-15-2022, 07:07 AM   #538
Huck369   Huck369 is offline
Huck369's Avatar
Originally Posted by Blueridge boyieee View Post
Anybody find an aftermarket air filter, like a twin air? I checked on a 2014 KTM 250 SX filter at the dealer and it was close but no cigar.
Also, if anyone visits the clutch springs, I’m looking for a stiffer replacement set.
Thanks
If my brother buys the new 6sp X, I’m going to be jelly, sent him the link this morning. When he’s up my way visiting, I never see him, his always out on my Templar…
You might try one for a 2007 Suzuki RMX250 since the plastic is a copy of that, maybe the airbox is too....worth a shot
Huck
2013 Honda NC700X
2013 Moto Guzzi V7 Stone
2016 AJP PR4
2022 Templar X 250
2021 Sondors Metacycle
AMA Life Member
Old 08-15-2022, 12:34 PM   #539
Exclamation Info on availability of the 6sp (ZS172FMM-5)
I got this back from maxpro-llc on the 6sp Zongshen engine:
"The ZS172FMM-5 (6 speed engine) will come, but do not have ETA right now, when it will arrived at our warehouse, we will email you, or you can follow our eBay store, thanks".
BUT, in the same email, he said that the tech guy was telling him the -3A an -5 are not identical (mounts). He doesn't know if the -5 can be adapted into the older frame I got a couple of months ago with the -3A.
I will have both bikes side by side within a couple of weeks and will be able to look more closely at it. If the upper connection and at least one of the others hold it so the front sprocket is lined up, it should be possible to make linker plates to get the other mounts secured.
Old 08-15-2022, 03:09 PM   #540
If they aren’t interchangeable I may just wait to see if a 300 comes later.
