Hello everyone !
I'm new here and i want to ask you something about my Apollo Rx250 db-36c 2020. What type of CDI it use DC or AC? I burned up 5 CDI's. Ok first time i had a stator and voltage regulator problem, i changed them, i checked all wiring system but last time when i connected a new CDI guess what? I burned it. Help please i think i'm starting to go crazy. Thank you |
Oh, btw motorcycle start with my old CDI but die when i hit throttle.
Easy way to check what cdi you have is test the connector with a multi meter. DC is powered from the battery when not running. AC gets power from the Stator while running.
2025 Lifan KPT 400 2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 (Sold) 2016 Black Hawk 250 (sold) 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel |
Yes.
Stators on 70s, 80s Suzuki GS series were AC, three wire. But they went through the rectifier where there is a diode to convert to DC. I thought this might be how these bikes are set up if they have a stator. Oh, and rectifier/regulator was one unit as I recall.
So your post #3 above Jerry (DC setup on the right) applies for this type of system, powering the CDI with 12v. ?? |
I didn't tried yet what Jerry said. But here is a picture with my wire plug for CDI. https://postimg.cc/5XSfw3XY
#8 | |
Yes ! I've seen this wire configuration on youtube, but i already tried a DC CDI and i burned it, ok, this was when i had shortage on stator, i will buy a DC CDI and i hope it will work, but i really tired to spend money on CDI's and motorcycle burns them when i press button.
#10 | |
apollo 250 rx, cdi, db-36c |
