#1 | |
Pilot jet on a CG engine with a PE carb you are looking at a 35 or 38 in most instances. Main jet with an exhaust and pod filter will likely be a 120 if you go with a PE28 - my suggestion if you just HAVE to have a PE carb. You will have to determine if that jet is the right one for you though based on density altitude.
Ive seen great results with the pz30 with a 125 main jet, did airbox delete , pod filter , cat delete. Really easy to tune
carb upgrade, carbeurator, hawk 250, jetting, nibbi |
