Old 09-27-2022, 03:48 PM   #11
Originally Posted by Huck369 View Post
I may have found the fix for those of us having issues with the rear brake, I took the rear slider bolt off, and left the lock washer off, and reinstalled with lock-tight, the Lock washer was causing the caliper to not have enough space, removing that lock washer made it work as it should.
PS, the headlight sucks, I'll end up adding some Aux Lighting
Confused about what you did. Any pics? How would it be better than adding a large washer inside the swingarm after the brake stay?
