Old 09-28-2022, 09:01 AM   #16
The only draw back on the KPX is that it doesn't need any real mods to make it run right. Kind of takes all the fun out of owning a china bike. lol
Old 09-28-2022, 09:27 AM   #17
Sport Rider's Avatar
did you have to do all the initial setup tuning? like greasing things, bolts, valve adj, etc? did you replace the chain or just running what came on it? I know both of the bikes would want a sprocket change, at least in the rear?
As for blaming you, that won't work. You're too far away for a bullet to reach and she'd ultimately just turn her attention back to me.
Old 09-28-2022, 10:16 AM   #18
Grease? I actually had to wipe grease off because there was excessive grease. lol No tuning needed, I just replaced the oil and out fresh 10w40 Valvoline motorcycle oil. Bolts looked like most of them had blue loctite already on them. I did go over most of them to make sure they were tight. I didn't adjust the valves as it ran to good. I will adjust them when i do the oil change which will be soon. I lubed up the stock chain which looked like is was already greased. I also cleaned up the rotors with brake cleaner. Brakes are way better than the hawk. good stopping power. I'm running stock sprockets. I'll be using it mostly for off-road but with the speed it is geared high enough if you plan on running 60-65 mph. Dropping 3 teeth on the rear would put it in the sweet spot for mostly highway.
Old 09-28-2022, 10:27 AM   #19
alex_in_az   alex_in_az is offline
that's why I got the TBR7, lots of things for me to mess with on it
2020 Tao TBR7
9.3:1 PnP head
CRF230F exhaust
4 degree advance key
290 degree cam
Nibbi PE30 and cone filter
Front fork brace
Old 09-28-2022, 11:12 AM   #20
Link to a freshly assembled 2022-1/2 Templar X
https://www.chinariders.net/showpost...&postcount=705
It is an enduro. I have made my 5 speed Templar X the off-road bike by putting the 49 tooth sprocket back on (swapped the entire wheel and chain from the new 6 speed). In the process, the new 6 speed got the 39tooth rear sprocket (and new o-ring chain). That, plus the 6 speed transmission will drop the revs for more sedate highway use.
So this new blue 2022-1/2 6 speed Temp X will be morphed into an adventure tourer, with luggage capacity. Those big adventure touring bikes like the Tenere (probably the smallest, most sensible one in the bunch!!) are just too big and cumbersome for anything more slippery than a graded logging road. I would hate to have to upright it from a spill
The Temp X is less than 270lbs wet, before luggage! And it has plenty of suspension to handle the luggage. It has a reserve position to help prevent running out of gas (a separate tube from each lobe can be selected at the petcock). Range is probably 175 miles, and I can carry a small bottle of extra gas to extend that in a pinch.
I will eventually replace the full on knobby on the 6 speed to a Tusk DSport, which it turns out is much smoother due to closer (and much bigger!) blocks and a flattened center. I have one on my Bashan Storm, and it is not only much smoother on the road, but amazing in the loose dirt, rock trails. The thing really bites in better than standard knobbies that come on these bikes.
I am going to look into shorter, or longer rear suspension dogleg links to drop the bike about an inch and a half. I can clamp the fork tubes up by an half inch or so. I might go with a Kenda K270 on the front. That is a compromise for adventure touring, running errands, and the occasional commute
Old 09-28-2022, 11:41 AM   #21
TominMO   TominMO is offline
The suicide-by-wife is a factor too. She'd probably shoot me less times over 2 grand than over 3 grand. That might be a change to live through it.
Good plan. You can recover if she just wounds you.
2021 Lifan Xpect--sold
2022 Lifan KPX
1972 Honda CT90--The Carrot
1969 Honda CT90--The Tomahto
Cheesy is the WDK (workplace drama king). Now retired. Nope, back in the saddle. Nope, finally retired.
Old 09-28-2022, 04:41 PM   #22
IdahoRider   IdahoRider is offline
Old 09-29-2022, 02:45 PM   #23
zero_dgz   zero_dgz is offline
Oh, "we" use this type of steel, do we? "We" powdercoat it and "we" do the wiring? My ass. I like how Orion is still steadfastly trying to pretend that they've done more than take an off the shelf Nicot motorcycle and put their name on it.
I'll tell you what's not machine welded: One of the mounting tabs for my battery holder already snapped off right at the weld. Whoever did that one up almost completely missed the metal, leaving a line of welding bead that barely touched the actual piece of metal they were trying to attach to the frame. That special automotive grade steel didn't prevent the threads from ripping right out of my seat mount bolt holes, either, nor did that machine welding ensure that the screw holes were actually lined up.
Don't be taken in by Orion's bullshit. The RXB is an okay Chinese bike but it's not close to anything special.
Old 05-26-2024, 10:37 AM   #24
Mic   Mic is offline
Any know if this X-PRO Templar X 250cc 6 Speed Dirt Bike can be registered and licensed in Penna. ??
Old 05-26-2024, 10:45 AM   #25
Mic   Mic is offline
Well sounds like your an accomplished ride as I have the same views on this ride... thanks
