If you need more room on the intake side you can always remove the motor mount brackets. That's what I had to do on my Ghost and X22R.
2025 Lifan KPT 400 2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 (Sold) 2016 Black Hawk 250 (sold) 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel |
#2 | |
I'm thinking that when they installed the motor at the factory, they either already had the lower bolt and nut in place, then installed the intake, then put it in the bike. Or installed the entire upper mount, then the intake. I don't see how they could have accessed that lower nut with the intake already there. When I propped the tank up, I left it on the front mount and just rotated the rear of the tank up, which ID Rider did not do. Looks like he also took it off the front mount and raised the whole tank. So that may be all I have to do. BTW Jerry, once I was all cried out and got a few consoling words from my psychiatrist via phone consultation, I was fine. Mostly.
2021 Lifan Xpect--sold 2022 Lifan KPX 1972 Honda CT90--The Carrot 1969 Honda CT90--The Tomahto Cheesy is the WDK (workplace drama king). Now retired. Nope, back in the saddle. Nope, finally retired. Climate: The Movie https://www.youtube.com/watch?v=A24fWmNA6lM How our government really works https://www.youtube.com/watch?v=QjadCd0VRBw Question all authority.....think for yourself |
Yes I lifted the whole tank up. The front of the tank just slides on to two rubber bushings. The wiring and fuel line to the tank is long enough that I could have raised it even higher but the two short pieces of 2x4 were just the right dimension to lift it up enough and hold it level. Once you lift the tank you'll see how easy it will become. (This is coming from someone who has never done this before).
#4 | |
lifan kpx 250, valve adjustment |
