Old 01-16-2023, 08:37 PM   #1
Fast_Freddy   Fast_Freddy is offline
Fast_Freddy's Avatar
Originally Posted by knwilson View Post
Wow. I don’t know why I never thought to use the rear brake. Didn’t know that would work…
Thanks for the insights.
Now back to figuring out why the hell this thing with 4 miles on it won’t start anymore.
The rear brake works on my base Templar and should work on the X&M also. Have you re-jetted yet? The first thing I did on my Templar was re-jet the carb. I started it once before that and it was obviously way too lean. I ground the float bowl screw heads off but if I had it to do again I'd just buy a new Nibbi, jet it with 125 main, 42 pilot and 2 turns out on the idle mixture screw and swap carbs. Mine starts and runs so much better with the mentioned jets.
Good luck.
22 Templar 250
Old 01-20-2023, 02:45 PM   #2
knwilson   knwilson is offline
Good luck.
What's your elevation if you don't mind? I am installing a Nibbi 30mm this weekend.
It comes with the following:
1 x Slow Jet
Available Size #40
3 x Power Jet
Available Size: #120 122 125
I'm at 1400' - Was thinking about starting with the #120 and #40...
Old 01-20-2023, 08:53 PM   #3
1 x Slow Jet
Available Size #40
3 x Power Jet
https://www.chinariders.net/images/smilies/nod2.gif
I'm at 450' ASL. My carb is 28mm and I expect a 30mm carb would need more fuel. I would probably start at 42 and 125 (FWIW). You might be okay with the 40 if you go 2-3 turns out on the idle mixture. GL
22 Templar 250
