Old 01-24-2023, 11:32 PM   #1081
Hap   Hap is offline
Thought I would post pics of a Templar x cat slit open and removed I found on FB. That thing has got to be restrictive.
File Type: jpeg 8C21C975-6B84-48DF-9AF5-835FE27CF453.jpeg (98.2 KB, 1590 views)
File Type: jpeg E50CE1C5-C35F-490E-8F85-EC6FF529C70D.jpeg (89.5 KB, 1549 views)
22 Templar X 250
Hand Guards
Custom Graphics
Pro Taper Grips
125 main 45 pilot jets
42 tooth rear sprocket
2010 Yamaha Vstar 1100 Silver Star
Old 01-25-2023, 12:38 AM   #1082
Fast_Freddy   Fast_Freddy is offline
Fast_Freddy's Avatar
They're rarely as restrictive as everyone thinks they are but removing it might free up a horse. More with a cam, porting, etc. I like the way it was done with a single cut. It makes it so much easier to keep perfect alignment when welded back together. Looks like I need a MIG welder and some practice pipe.
22 Templar 250
Old 01-25-2023, 01:51 PM   #1083
Whether it winds up being 1hp or 2hp from removing that cat, it is definitely felt in the seat of the pants as i can attest when the pipe was replaced on my Brozz. I look forward to doing it on the TempX.. wish they had a replacement header that fit on Amazon
Old 01-25-2023, 02:32 PM   #1084
NCtemplar250   NCtemplar250 is offline
Hypothetically, if it does improve flow, then running a bigger carburetor and jetting appropriately should yield even more...right?
Old 01-25-2023, 02:53 PM   #1085
I'll defer that to our very own MegaDan who can hopefully chime in walk us thru those hypotheticals with real world experience..
Old 01-25-2023, 03:00 PM   #1086
The replacement carb listed in the Templar 250 resource guide is not available for purchase on Amazon, and it's a 30mm. Wouldn't the carb I have listed below be the better choice? It is a 28mm (just like the stock Templar 250 carb) and it's available for purchase:
https://www.amazon.com/Keihin-KIMISS-Carburetor-CR80RB-1996-2002/dp/B07H6L1GWV/ref=sr_1_14_sspa?crid=F3VN0W37NV2&keywords=youall+ 28mm+carb&qid=1674676612&s=automotive&sprefix=youa ll+28mm+carb%2Cautomotive%2C84&sr=1-14-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEzMkpXU 1BXRURKODk2JmVuY3J5cHRlZElkPUEwNzg0MzExMzBRNlVLVjk yNE9HUCZlbmNyeXB0ZWRBZElkPUEwMTY4ODcxMlFTQVVVV1MyV ktGUSZ3aWRnZXROYW1lPXNwX210ZiZhY3Rpb249Y2xpY2tSZWR pcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
Old 01-25-2023, 03:57 PM   #1087
https://www.amazon.com/Keihin-KIMISS...NsaWNrPXRydWU=
Thats the same carb, it looks like the one i ordered is no longer available on Amazon and it was a bit cheaper. I'll update my link to the one you listed - thx
Old 01-25-2023, 04:16 PM   #1088
Cool--thanks!
Old 01-25-2023, 06:03 PM   #1089
Oh No Nix on the pod filter idea
I have seen posts here where people ask if anyone has tried a pod filter on the Templar X. I don't know about the Templar and Templar M, but the carb on the Templar X aims at the rear shock spring, and there just isn't any room for a pod filter.
But, the snorkel has a nice smooth internal surface that snakes around to a VERY LARGE opening with a BIG OILED DOME FILTER. I don't think a pod filter would be better even if you COULD get it in there! In fact, a pod filter might be more restrictive. That dome filter offers a lot of surface area and it is very porous. Air must flow past that dome filter quite freely, and the large surface area allows for good filtering as well.
I think the answer is to keep the dome filter clean, and replace it if it gets too fouled to clean.
If you install a different carb, good luck on mating the snorkel. If you changed your carb, have you got a picture of this????
Old 01-25-2023, 08:07 PM   #1090
Below is the windshield I'm thinking about getting. I want something minimal--similar to what you see on KTM and Honda Rally. Ebay link below.
Here's a link to it on Ebay:
https://www.ebay.com/itm/18566811144...MakeTrack=true
Old 01-25-2023, 08:12 PM   #1091
If you get it be sure to post up pics installed.. Here is what i had installed in the past on my son's Brozz:
Motorcycle Small Windshields,Universal Windscreen Wind Defector w/Mount Bracket Fit 5 to 7" Round Headlights,for Yamaha Suzuki Kawasaki Triumph Ducati Chopper Cruiser(Black
https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
Old 01-26-2023, 06:41 PM   #1092
Zooker89's Avatar
Air/fuel mixture screw location?
Is the mixture screw hiding behind the silver cap that is between 7 and 8 o'clock from the idle screw when looking at the carb straight on?
Thanks in advance
Old 01-26-2023, 07:38 PM   #1093
Thanks in advance
Yep.
All:
Over on thumper talk someone claims that one of the headers off of a “250R” will fit the Templar-anyone else verify that?
Old 01-26-2023, 10:56 PM   #1094
Only thing that really makes me wonder is airflow to the air box-the battery tray takes a lot of room.
Old 01-27-2023, 11:25 AM   #1095
Hap   Hap is offline
Popped the bud fuse coming off my battery today-I can clearly see 250v but not the amperage-are they 10A?
Edit: No auto parts stores within 40 miles of me have 10a 250v glass fuses. Lol. WTF man.
Edit II: The bike cokes with a spare in the fuse box! Ha!
Hey Okierider. I’m embarrassed to ask. But where is the fuse box?
22 Templar X 250
Hand Guards
Custom Graphics
Pro Taper Grips
