Old 03-10-2023, 12:56 AM   #1
XLsior   XLsior is offline
XLsior's Avatar
Walmart CG250
I was general searching CG250.
This popped up
https://www.walmart.com/ip/Vertical-...roke/288560980
Old 03-13-2023, 04:32 PM   #2
buzz   buzz is offline
Anybody try one,be nice to know?
Old 03-13-2023, 06:58 PM   #3
XLsior's Avatar
Don't have Walmart in Australia...
But it looks to have a proper serial # starting with a ZN?
Old 03-13-2023, 07:34 PM   #4
167FML, probably Zongshen, but the engine model number doesn't include the ZS (ZS167FML).
I see a typical 6 (5 wire) bus digital gear indicator connector, the starter wire (beefy red covered wire to connect to the starter solenoid). The stator wires are individual, but could easily be converted to a connector or custom wired.
Looks good to me. You can pay less through AliExpress, but those vendors may not use good packaging, and Walmart will refund if the thing is damaged.
Old 03-18-2024, 10:27 PM   #5
Chance17   Chance17 is offline
I have this motor trying to figure out the wiring the plug has five wires … pink,yellow,black&red, green$white,, blue white how should I wire this and is it ac or dc
