Old 06-28-2023, 10:15 AM   #661
Barnone   Barnone is offline
Barnone's Avatar
Originally Posted by Dadbike26 View Post
Anyone using Sta-bil or anything to your gas? If so what do you use or recommend and how much per gallon? I’m wondering if this will help my engine run better without choke. :-(
Shouldn't need Stabil unless you let the bike set up for a long time. I usually never even use the choke to start her up.
Old 06-28-2023, 10:22 AM   #662
Barnone's Avatar
Vince, no pictures of the trip?
We are here in the mountains of WNC until October then we head back to SWFL for the winter.
My Ural at the overlook on the Dragon ETN. Will post some DF photos soon.
Old 06-29-2023, 06:46 AM   #663
Dadbike26   Dadbike26 is offline
Off topic but…
Nice I had never heard of the brand Ural, but really like the side car, classic look.
Reminds me of Indiana Jones!!
Old 06-29-2023, 06:48 AM   #664
Off topic but…
Old 06-29-2023, 06:51 PM   #665
Barnone's Avatar
My DF by a old barn being torn down down the road a bit from our place in the mountains of WNC. The owner passed away years ago and I bet he is turning over in his grave.
Old 07-05-2023, 09:33 PM   #666
Barnone's Avatar
Just beck from a Busa Down Patrol looking for motorcycle wrecks here in the mountains of WNC. No wrecks found. LOL
Old 07-09-2023, 04:22 AM   #667
Hey any service stand recommendations? This bike really needed a center stand since it isn’t compatible with the sport bike rear stands.
Old 07-09-2023, 04:26 AM   #668
Df250 rtg
Practicing early mornings in an empty parkingClick image for larger version
ID:	29636 lot for my motorcycle road test.
Old 07-09-2023, 04:32 AM   #669
Df250 rtg
Old 07-09-2023, 08:39 AM   #670
Also one have an issue with their brake lights? My front and rear brake light dose not engage when pressing the front brake lever or pushing down on the rear brake.
Does anyone have experience with this issue or any ideas what this issue can be? By the way all the other electrical functions work fine. Including the tail light.
Old 07-10-2023, 09:38 AM   #671
Burnt Bulb?
Old 07-10-2023, 02:54 PM   #672
grumpyunk   grumpyunk is offline
grumpyunk's Avatar
The brake lights will only glow when the ignition is switched to ON. They use battery power, as do the headlights. If you have no light, the most likely spot to look would be where the switches(F & R) get their power as they are fed separately. Likely inside the headlight bucket. Find the wires that feed the switches - one to power(B+), the other to the F&F light sockets. Both switches use ignition switch controlled power.
A quick check is to see if you have power to the rear brake switch, kind of out in the open and easier to access. Check for power on one wire with the ignition ON. If no power, follow the power wire back to its source of power.
Ignition switches of old had a 'park' feature that would send power to the rear tail light, used to mark the bike presence in the dark in narrow allies/ways. The position was separate from OFF/RUN. FWIW.
You could also check for B+ at the ignition switch, both IN and OUT.
tom
vertical and above ground - my daily goal
Old 07-10-2023, 04:09 PM   #673
Barnone's Avatar
I agree that it needs a center stand. I have tried to adapt several but no luck.
I used this kinda hokey arrangement on mine.
Old 07-10-2023, 04:37 PM   #674
Barnone's Avatar
Burnt Bulb?
Yep, check the taillight bulb. I just went and checked and the bulb lit up with either the hand or the foot brake.
Old 07-12-2023, 06:46 AM   #675
I took the rear light apart and saw that the light is a bunch of small LED bulbs. They are all illuminated when running, but don’t get brighter when brakes (front or rear) are engaged. The tube fuse in the plastic case near the battery seems to be intact, are there any other fuses to look for?
Barnone, do you have the same stock LED taillight/brake light ?
I’m wondering if I need a new brake light fixture ?
