#1471 |
Something like this. Obviously would need a different spring but likely an endless list of compatible components.
#1473 |
It looks GREAT !
Did those wheels come with the red stripes? Good for visibility in traffic
No matter where you go, there you are... "It's the environment, stupid" ("No planet, no jobs" ) Last edited by Thumper; 09-01-2023 at 03:40 PM. |
#1474 |
Took the Templar out for a ride with a buddy. It really is a great bike for the money.
#1475 |
So I have a 5sp non-counterbalanced. One of my front engine mount bolts worked it's way out, the other fatigued and broke with the slightest turn of a wrench. Bike was super buzzy on the 30 mile ride home. Turns out the extra vibes broke the upper engine mounts (as well as the petcock holder bracket). I relocated the petcock to the frame with some wire, it will work until I come up with something else. Looking to source some beefier upper mounts to replace with. Crf230 mounts look like a potential. Any thoughts on this?
#1476 |
My advice, stick with OEM mounts. But use loctite. It is a stiff enough mounting bracket(s), and it'll hold, no problem.
No matter where you go, there you are... "It's the environment, stupid" ("No planet, no jobs" ) |
#1477 |
They were extras that came with my Beta. Just got lucky and they matched the color pretty well.
#1478 |
oil capacity
what is the oil capacity for templar x 250.
#1479 |
1.25 quart
22 Templar 250 |
#1480 |
I just got a Templar X and did an oil change of the oil that it shipped with, according to the dipstick it was full at 1 qt, you run 1.25 qts without issue?
#1481 |
Did you screw in the dip stick to check level? Because typically you don't with Honda clone engines, the oil level is read with the dip stick unthreaded as a loose dip...
#1482 |
No, it was full at 1qt, I just want to confirm how much more oil is safe to run?
#1483 |
Was the oil warm when you drained it? Did you remove and clean the filter screen? If no to either you probably have a few ounces of old oil remaining. Go by the dipstick.
22 Templar 250 |
#1484 |
Thanks Thumper
