Old 06-23-2008, 09:31 AM   #1
alonzo   alonzo is offline
good times
well the bike developed a new illness today. this morning I went to start the bike. I pushed the starter button, and all of my electronics quit, horn turnsignals neutral indicator ect. so I whipped out the kickstarter and she fired on the first try.
this is going to be a reoccuring problem I just got home and it is doing the same thing turn on the ignition signals work as well as the rest of the electronics, as soon as I hit the starter button everything turns off.
I was thinking the relay has something to do with the problem because as soon as I hear the relay click, everything shuts down.
any advice?
thanks fellas
ALONZO 2007 Lifan a.k.a lucy lu. 2,000 miles of good riding.
Old 06-23-2008, 09:49 AM   #2
DesertDog   DesertDog is offline
sounds like a starter switch problem , whip out the ol- multi meter and start with the ohlms, testing for open and closed wires.
i dont knowww !
could be a wire is grounding somewhere.
my sons bike the starter will just start to ingage while ridding so we've learned to just smack the starter button and it quits till the next time
DesertDog
Old 06-23-2008, 11:58 AM   #3
VinceDrake   VinceDrake is offline
Also could be a case of bad power or ground supply-- i.e. Check the ground wiring from the battery. ALso check the power wire. Could be a bad connection there, So there's enough amps to run the instruments, but when a heavy load as applied-- such as the starter, there's just not enought power there...
--Vince
"Sometimes it is better to say nothing, and let people think you're an idiot, than to open your mouth and prove it."
Old 06-23-2008, 12:08 PM   #4
red2003   red2003 is offline
Is the battery charged all the way. Might be down on power and the starter is just sapping it.
Old 06-23-2008, 01:54 PM   #5
after my trip lastnight I checked the battery it reads 13.5 volts. as for the wiring... I will be checking that tonight.
I decided to risk it and hit the starter button while I had the bike was running, the lights went dim and there was no classical whine/grind from the starter.
maby the naming of the bike was wrong, she no love me long time 1,400 dollar
Old 06-23-2008, 04:16 PM   #6
so started pulling off electronics and all the connections looked pretty good there was a little melting on the negative terminal and this little guy on the relay.....
the guy back in china put the relays' lock washer on the underside of the contact :roll:
as the pic shows it was only making contact with half the surface.
I am pretty sure that in order for electronics to be 100% functional that the contact needs to make as much surface to surface contact as possiable.
thanks you for the advice fellas,
PS
sorry this image is a monster :oops: I tried to resize it, just didn't work out.
[img][/img]
Old 06-23-2008, 08:16 PM   #7
PS
[img][/img]
yu no breaky rice bowl ita wunt like yu. awsoe
DesertDog
Old 06-23-2008, 08:24 PM   #8
lol yes DD she still love me long time 1,400 dollar.
Old 06-23-2008, 08:31 PM   #9
she so hony, liky liky long time
DesertDog
