#16 |
Did you order one of those 450s thru Alibaba?
Kamax has a 2 stroke 250 I toyed with ordering. I had problems with AliExpress vendor over a cylinder head and decided that the combination of shipping cost, shipping risk, and potential reimbursement fail was just too much on a crate bike from somewhere in mainland China. AliExpress backs the vendor in a dispute, even with photos. Then removes emails promising shipping credit. It' is Alibaba, but I think it's basically the same thing.
No matter where you go, there you are... "It's the environment, stupid" ("No planet, no jobs" ) |
#17 | |
https://www.temu.com/zsdtrp-35mm-40m...498_c4m9jd99zh |
#18 |
Who sells a upgraded cam for the Templar 250 looking at a big bore kit for it.thanks
#19 | |
#20 |
What model and year are the plastic on the standard Templar 250 thank you.
#21 | |
Edit: this is for the X model, I am not sure which bike fits the base model but my guess would roughly 10yr old KTM's.
Templar X Vitacci Clash 200 Beta 300rr GasGas TXT 125 Last edited by Mikd; 07-11-2024 at 07:11 AM. |
#22 |
PR300 Engine = 271.3 cc only 6cc more than the big bore kit 265cc
#23 |
The nibbi pwk 30 is a great carb. I put it on my titan 250. Made a huge difference even more so with a cam and other mods. I had quite a time stuffing it in there but we'll worth it. I had to cut the mounting flange off the manifold on the carb side and weld on a piece of aluminum pipe. I didn't have good results with the nibbi boots. They didn't hold up to vibration. I ended up cutting a small piece of heavy duty radiator hose from a diesel forklift. The kind that looks spiral wrapped on the outer wall. Nobody will miss it.
#24 |
For a 300, a pe32mm or PZ32 is more than enough, unless it's an overhead cam engine with 10+k rpm.
