Old 08-11-2008, 03:05 PM   #1
troll4965   troll4965 is offline
Send a message via Yahoo to troll4965
Qingqi RS450 with a GY6 50cc Need Help
What I'm looking for is a cheap why to get more speed out my scooter. Is there any why to get more speed out of it by disabling any sencors?
Old 08-11-2008, 05:38 PM   #2
chrism1   chrism1 is offline
Unplug taillight and push it down a hill?
LOL....I am not aware but someone will chime in.............
Lifan LF200GY-5
Old 08-14-2008, 11:20 AM   #3
CathastrophiX   CathastrophiX is offline
http://scootdawg.proboards59.com/
"Failure is always an option!"
Qingqi QM200GY -06
Old 09-08-2008, 01:11 AM   #4
DesertDog   DesertDog is offline
hey Troll
if your mechanically inclined , i'm not a good speller,
and have all the means to work on these scooters, there are lots of tricks
most are not cheap tho.
one cheap one is to cut open the muffler gut it out put it back together, (this is where you need a welder), once together try it out it will be louder.
look on e-bay for a uni filter, check the mm size of your carb, cost for the uni-filter ? 5 , 10, or $15's . and then dump the stock airbox that thing is robbing you of air anyway.
then get may 1 or 2 sizes bigger main jet depending on your elevation,
like the one in there is a 105mm , go up to a 110 or a 115, just using that as a figure of speach.
just doing that you should notice a pretty good jump in power, but nothing to write home about.
another trick is change the clutch spring , those are cheap just acouple a dollars ea.
if you want quick take offs then change the rollars in the variator, say you might have 10 gram or 12 gram rollers go up to 15, 16 or 18 gram rollers
these are less than buying a H.P. clutch or variator
remeber the heavier rollers will give you higher rpm's sounds at lower speed,
or just go here and read up on these idea's i've given you
www.oregonvintage.com
i could go on and on about this stuff
so hope you got it done already and this is old news to you
DD out
Old 10-14-2008, 06:42 AM   #5
pedez2000   pedez2000 is offline
email me below i sell racing parts and can walk you thur a few cheap ways to go.
racing coil,plug,cdi,jets,airfilter (free flow)roller/slider weights biggest bang for you buck.
all above for just over 100.00
dirty south choppers LLC
www.roketaparts.net
powersports dealer
parts and service
www.sunlparts.net
kelly stevenson and Gregg martinez
sales@sunlparts.net
Old 02-22-2009, 08:49 PM   #6
PremierScooters   PremierScooters is offline
there is no replacement for displacement. Put on a 70 or 80cc big bore kit. Not cheap, unless you can do it yourself (still not too cheap). There is only so much a 50cc 4 stroke can do. Most Chinese scoots do not come regulated to 30mph like the name brand ones do. Air filter, jet, rollers, clutch springs, torque spring, exhuast, CDI, coil, spark plug will all help a little but there is a point of diminishing returns.
Premier Scooters,103 N. Hwy 25 Byp, Greenville, SC 29617 Phone 864-294-0042 Specialzing in Chinese Motorsports, Sales, Service and Parts
