My heart transplant thread
81 xr200r, bought for 750
crashed broke the fork and speedo, replaced with 84 200r fork (better) broke the wheel ![]() then killed the motor got a 163fml Lifan motor and wiring harness took some mods: used honda intake (piece between the carb and motor) used honda carb top and piece that holds throttle cable in had to cut motor mount spacers and use washers to make fit need to get 520 sprocket that fits my honda chain dont think pipe will fit and theres more im not done yet heres some pics of my progress not in order ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Looks like you are getting along fairly well :wink:
You seem to be pretty motivated, so you should be able to get it dialed-in. That harness doesn't look quite as intimidating while coiled up on the ground, as it does coiled around the bike frame 8O Good progress, keep us posted, Tigertamer
07 H-D XL883C 06 LF 200GY-5 Yin and Yang CAUTION Obey The Traffic Regulation. Always Wear a Helmet. Don't Ride After Drinking Wine. Before Operation, Read The Owners Manual Carefully. |
I think you'll find the chain won't line up, I believe that Hooper Imports have had a special sprocket made to rectify this.
Jonathan. |
sweeeet!
#5 | |
![]() Edited by Iron. |
Check with Bruce at EJcycles. 330-274-0098
He has 520 front sprockets for the lifan engines. Allen
thanks, i just got one, just need time to work on itn now
![]() ![]() ![]() got it together it runs well needs a few things, im gona start painting the plastics black rite now |
if anyone is interested in doing this see my thread on thumpertalk.com i talk about evertrhing needed to do it(under xr/crf80-200)
Yup, definatly looks better is black! Congrats on a nice swap!
All in all do you figure more or less power with the China-built engine? Less/More Speed? Thanks for your post! --Vince
"Sometimes it is better to say nothing, and let people think you're an idiot, than to open your mouth and prove it." |
#13 | |
