Old 09-28-2008, 01:01 PM   #1
Frog   Frog is offline
GY5 - chain tensioner - huge improvement
Hi
as other have pointed out the Lifan GY5 needs a lot of chain slack - over 3 inches when on the side stand to make sure the chain does not get tight under suspension compression. 8O
To compensate for this I have just fitted a universal chain tensioner - cost about 15 dollars (£10 UK pounds in my case). The one I got is I think called CEMET - and is a pad rather than roller design. This mounts on to the little plate on the swing arm that usually holds the useless white plastic chain guide (that appears to do nothing!) near the rear sprocket..
I mounted the tensioner onto the front hole having drilled and tapped it for an 8mm bolt and mounted a stop for the tensioner spring in the rear hole - these are perfectly placed for the job.
The result is astonishing and disproportionate to the effort and expense involved - bike feels entirely different and has picked up an undefinable air of quality about it - smoother / less vibes and gear change improved. No chain slap - transmission is getting an easier time. Feels tons better.
If anyone wants a pic let me know and I'll post one but basically very easy to do and well worth it.
Frog
Old 09-28-2008, 01:18 PM   #2
chinaguy   chinaguy is offline
I would really appreciate it if you could post a pic.
2008 HSUN GY 200
Old 09-28-2008, 02:44 PM   #3
Picture below - the tape on the swinging arm is nothing to do with the tensioner - it holds my chain oiler!
Cheers
Frog
Old 09-28-2008, 02:58 PM   #4
Thanks. Now I can see exactly what you mean. Looks like a big improvement over the stock rubber slider.
2008 HSUN GY 200
Old 09-28-2008, 03:06 PM   #5
By keeping the chain under tension the difference is like between riding a road bike with a badly adjusted and shot chain and replacing it with a properly adjusted new one! This is, I think, the only way to get that on my bike without major surgery - even with a good chain you need too much slack normally - this absorbs that slack. It actually feels 'right' for the first time since I've had it.
Frog
Old 09-28-2008, 03:34 PM   #6
forchetto   forchetto is offline
I could do with one of those on mine.
I've searched for CEMET but found nothing.
I then Googled "universal chain tensioner" and found this:
Is that anything like yours?
They have one here for a mere £7.90, they appear to be the same:
http://www.trialsbits.co.uk/product_...roducts_id=498
Jincheng Monkey JC50Q-7 (two of them)
Skyteam Dax replica ST110-6 (two of them)
Zongshen ZS125-43
Qingqi QM200GY-BA Super Motard
Yamaha Virago XV1100
Triumph Bonneville SE
Qingqi QM110GY
PGO Bug rider 250 Buggy
Old 09-28-2008, 03:41 PM   #7
That is almost identical and should work equally as well.
Have a look at this item also 370070105492 - cheaper and in Portugal
regards
Frog
Old 09-28-2008, 06:41 PM   #8
knothead   knothead is offline
I've seen some of the "grey market" Lifans with a setup that mounts below the swingarm near the pivot (towards the front) and uses a polyurethane roller. It's spring loaded like the one you guys found. I've been thinking about making one as it would be pretty easy to do, but if I can find one like your's here in the US it might pay to just buy one. (but then again, with the dollar in the shape it's in....)
Old 09-28-2008, 08:05 PM   #9
DDG1976   DDG1976 is offline
Send a message via Yahoo to DDG1976
Heak yea, somebody find and post a link to get one in the US, that looks like a perfect fix for these bikes.
I have all of soberday to satur up!!
Old 09-28-2008, 08:12 PM   #10
Looks like a teflon cam chain tentioner, cheaper I'd bet
IronFist
The "chain" of command is used for beating spammers.
Old 09-28-2008, 08:15 PM   #11
Jim   Jim is offline
That looks good, I've been thinking of finding something like that myself, thanks for sharing
"Be excellent to each other"
"We are all human. Let's start to prove it!"
Old 02-20-2009, 04:47 PM   #12
Chain tensioner Qinqi QM200GY-BA (Qlink XF200)
Just completed the fitting of a drive chain tensioner to my Qingqi. I wasn't too happy with the idea of the chain sliding against a plastic pad, so I modified a universal $10 tensioner with a ball bearing roller set-up.
Works a treat. No more chain thrashing noises, no more chain snatch at low revs, and gearchanging is even better and more precise now. Thanks for the idea, Frog.
This is the standard tensioner as bought:
This is the ball-bearing plastic roller or pulley:
This is the tensioner modified:
Here seen attached to one of the existing bolts that hold the lower chain guard. No modifications were made to the bike at all:
Close-up view:
Zongshen ZS125-43
Qingqi QM110GY
Old 02-20-2009, 05:14 PM   #13
suprf1y   suprf1y is offline
If anybody is looking for one of these, search ebay for pitbike parts. You'll find the universal ones cheap.
Old 02-20-2009, 07:25 PM   #14
PremierScooters   PremierScooters is offline
I'll have to try that. I sell a 125cc pit bike that has a roller type chain adjuster. I'll have to see if my supplier's parts department has one.
Premier Scooters,103 N. Hwy 25 Byp, Greenville, SC 29617 Phone 864-294-0042 Specialzing in Chinese Motorsports, Sales, Service and Parts
Old 02-20-2009, 08:23 PM   #15
SpeedSouth   SpeedSouth is offline
Any chance for a link?
A search of ebay for a universal returned 3 total, only one in US for $44
http://cgi.ebay.com/ebaymotors/_ATV-...1%7C240%3A1318
I searched for pitbike parts and found zero tensioners in 169 parts listed. :(
Can I buy a vowel? 8)
2008 American Lifan LF200 GY-5 (930 km) - Sold
2007 Kawasaki EX250 - Sold
2006 Kawasaki EX650R - My new ride!
2005 Kawasaki EX250 - A new project
